BX25 ALTERNATOR UPGRADE
   / BX25 ALTERNATOR UPGRADE #51
Artisan
How old is your Bx and how many hours do you have on it?:rolleyes:
   / BX25 ALTERNATOR UPGRADE #52
I would start with a GOOD starter/alternator shop. We have a couple good ones in Sacramento who deal with this, or customize one to meet your amperage needs. You're in the LA area; there must be some good alternator/starter shops down there...
Artisian I would have to second this. I had a shop build me an altenator for a snow plow truck that blew away the big name brands at a much lesser cost. Food for thought.
Chris
   / BX25 ALTERNATOR UPGRADE #53
Just another idea to throw at you;
How about a hydro motor to drive your winch, instead of electric? You could run it for as long as you wanted, and move it front to rear as needed.
Bill
OK, here is the info, now someone prove me wrong.
The Kubota # is 19630-64013 (DENSO # 101211-2961) it's a 60 amp unit. :checkeredflag:
This should be a plugNplay bolt-in 33% more output Alternator for a BX25.
Harry it is a 2012 Unit, 51 Hours, I think 8 months old.
Yes, I fully understand the ramifications.
   / BX25 ALTERNATOR UPGRADE #57
I have no way to prove you wrong but let you buy it and attempt to install it and check the fitting. ;) but if it works then ---> :cloud9:
   / BX25 ALTERNATOR UPGRADE #58
Brad, be sure to take your current alt. with you when ordering to crosscheck. Be sure to let us know!!
Chris
Well... That is step one. "I" totally suck at electronics, pittifully so.
I need to find out what could go wrong, or will nothing go wrong so long
as it is only a higher output alternator?
I have yet to have a 12V
expert w/ credentials tell me Yea or Nay...
My BX25 Full Cage Rollbar is not complete
although it is all cut, bent & fitted. Design Alpha is done and I await a professional welder
to break free to come over and tack it all up w/ me helping then disassemble,
go back to his shop to TIG it all up w/ gravity working for us. Gawd his welds
are beautiful. I have 3 Miller welders but that, I am calling in the pros. I need
to finish that task before jumoing head first into another, tis why I explain.
This is leg work for a project down the line. Still much to be alalyzed. The alternator I spec herein
is on EBAY right now w/ great pics for $249.00 so you can go look at it. I found THIS
as well, possibly an aftermarket unit for $87.20 .
If someone does this before me please post up pics and info here.
   / BX25 ALTERNATOR UPGRADE #60
This is an interesting thread, because it does not seem the issue it used to be. When I first got on TBN, and having an older "B" series at the time, they were notorious for having tiny dynamo's, and very dim headlights; my Mini-Mag Light was brighter than both headlights. Now, you alternator has significantly more output, and tractor much better factory lighting.
I'm interested to find out how this pans out for you... Also curious if this might be an option on the older tractors... I know the guy that bought my B8200; it is still going strong, albiet with pitiful stock lighting and that itsybitsy dynamo.
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
24017 (A56859)
24017 (A56859)
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
