BX24 with a Patu DC 40 chipper
   / BX24 with a Patu DC 40 chipper #2
Wow,
another Rhode Islander.
Yes, I run a Wallenstein BX42 chipper and the tractor handles it fine. I can run it to chipper capacity with out any power issues. Just check the weight /physical size of the chipper those will be the limitations of a 4" chipper.
Hey, what part of RI are you from?
Weight seems to be close the BX42 model at
403 lbs (183 kg)
   / BX24 with a Patu DC 40 chipper #4
Richmond, I believe you will have no problem as long as it's the manual feed model. The BX does not have enough hyd flow to run a feeder.
Your not too far from me I'm in Ashway at the Westerly line. Yes its the manual feed. I am going to go check it out this weekend make sure its not destoyed. They are asking 1200$ for it.
Well I bought it, for 1,000$ worked really well off the back of the sellers 1980's Ford tractor. Now I just need to take it out the back of the truck and put it on the BX.
   / BX24 with a Patu DC 40 chipper #7
Congratulations on your purchase! Let us see some pictures of it mounted, and maybe running! :D
   / BX24 with a Patu DC 40 chipper #8
Sweet Deal! I would like to have come across a used one at a fantastic price!
Let's see some pics!
   / BX24 with a Patu DC 40 chipper #10
3412 RPM equals 540 rpm at the rear pto. That is the minimum speed to run the chipper at. I just run it full rpm.
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
