Bx24 weight
   / Bx24 weight #1
Keithctc
I am purchasing a BX24 with a 60" deck. I will have to buy a trailer for this machine so I emailes Kubota about the total weight. Surprisingly they said that the BX minus the deck weighs about 1530. The deck adds another 200lbs. Does this seem right? I think that the bare tractor, no FEL and backhoe might weigh @1530 Does anybody know? Thanks Keith
   / Bx24 weight #2
He must be quoting a BX tractor. The BX 24 with the FEL and backhoe tips the scale at about 2250 lbs. The 60 MMM adds another 250-300lbs. It's about 2500lbs complete. You might be able to squeeze it on a single axle 3500# 14' trailer, but it's not recommended. You should go with a dual 3500# 16' with brakes on both axles.
   / Bx24 weight #3
Asylum is correct. IIRC, the 1530 is the tractor + loader. This is the number that shows up on the specs for the BX TLB, even tho the "B" weight isn't included. This little glitch by Kubota has caused much confusion. The hoe adds another 700lbs or so.
I had my trailer + BX22 weighed. Total was 4000lbs, minus about 1750lbs of trailer leaves about 2250lbs.
As suggested, go with a double axle trailer. My 17ft car hauler was used to move my BX22 (recently sold) and now moves my B26 (4000lbs).
   / Bx24 weight
Thanks for the info- It seemed that the spec sheet was not right I was surprised that Kubota's reply to this question was answered incorrectly -oh well? I decided to go with a 16' trailer with dual axles just to be on the safe side. Thanks for the help - Keith
   / Bx24 weight #5
I have a single axle for my BX24 (60" too, sweeper). I do not need a duel when I do not travel far with it..
   / Bx24 weight
Frank, Are you happy with the way your 60' deck cuts on the BX? Keith
   / Bx24 weight #7
Have not used the 60" yet...only had the 54":D
   / Bx24 weight #8
Keithctc said:
... I was surprised that Kubota's reply to this question was answered incorrectly...
I too have been surprised to experience a similar phenomenon with Kubota. I have contacted several people at Kubota.com over the years, and have received incorrect answers to questions on several occasions. When I took the time to point out obvious innacurracies in Kubota replies, officials either didn't follow-up, or seemed indifferent about their mistake. I find this corporate behavior to be unprofessional and hard to believe.
   / Bx24 weight #9
2250lbs sounds about right as I guesstimate my BX23 @ 2500lbs fully loaded (FEL, BH and 60" MMM)
Not Frank but I've been finish mowing alittle over 4 acres w/a BX23 & 60" MMM going on my 4th season and I find the finish quality to be as good or better than any of my previous L&G and lawn tractors. I'm using gatorblades now which has improved the cut and shreads the clippings finer than the OEM std blades. The OEM blades did provide a good cut also btw. When asked, I recommend the BX w/a 60" MMM :D
I agree w/this statement as it is the safest way to tow but
I've had no problems todate towing my BX23TLB on my little used 6x12 3500lb single axle trailer for short distances (15 miles and less). If I were to regularly tow I'd go w/a minimum of a 6x14 7000lb dual axle w/electric brakes.
   / Bx24 weight #10
60" deck rocks. Plan on a solid 2,300# for the tractor, FEL, and BH.
I have a rig similar to Mr. Volfandt. The single axle just doesn't cut it. No question. Don't make the mistake if you're buying a new trailer (I already had mine and HOPED it would work...it doesn't...too floppy and tippy)
After much consideration, I am about a week from pulling the trigger on a 10,000# dual axle 7' x 16' wood deck dovetail with weight distributing hitch for $3,425. I had my eyes on a 7,000# flat wood deck with folding ramps for $2,100 ($2,525 with weight distributing hitch), but my wife deemed it "wimpy" and wanted something that "looked stronger".
Who am I to argue? My discussion is here: http://www.tractorbynet.com/forums/trailers-transportation/117665-7-000-vs-10-000-a.html
2004 Ford F250 (A50515)
2004 Ford F250...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
John Deere 920 Platform (A50514)
John Deere 920...
2016 Bobcat S850 (A50120)
2016 Bobcat S850...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
