BX24 vs B21 TLB ?
   / BX24 vs B21 TLB ? #11
Miles2go,
Think I would go along with the others and say that even though the two have similar horsepower they are not the same class machine. It would be a good experience as you try and decide how much tractor you need to rent the B21. Have at some of those trees you want out and see how much effort it will take with the smaller TLB.
Just a couple words of caution if you rent. You have said you are new to tractors like all of us were at one time. Also it has been mentioned that your property is rather hilly. Hills and tractors require some basic cautions to avoid problems. Try to minimize the amount of side hill travel you do. Over 15 degrees on a side hill can feel pretty uncomfortable and is generally considered about the max you want to take a small tractor. Drop the low side into an unseen hole and you can find yourself in trouble. Always keep the loader bucket as close to the ground as possible so that your center of gravity remains low. Go slow!! With the B21, if you find yourself on a slope where you feel uncomfortable lower the stabilizers close to the ground until you get to a more level surface. Do not shift from one transmission range to another while on a hill. There is a lag between ranges that can make the tractor free wheel if you get caught between ranges. Wear that seat belt just in case.
Sure hope I don’t sound like I am preaching to you. It is just hard to know what you can expect from a tractor until you have a few hours under your belt and hillsides can be tricky for even experienced operators.
MarkV
   / BX24 vs B21 TLB ?
MarkV,
Thanks for those pointers. I tend to be cautious, so you are preaching to the choir -- but I never mind hearing a safety sermon.
   / BX24 vs B21 TLB ? #13
The point about lowering the stabilizers is a good one. A freind of mine has an apple orchard that's basically mid-slope on a cliff. Makes for great views, but tough walking, and even tougher tractoring. He contracts out the hole-digging to a neighbor with a small TLB (not sure which brand, but it's 1-seat true TLB, and not a CUT with a BH attachment). The (brave) neighbor traverses this slope with the hoe fully on the uphill side, and the downhill-side stabilizer nearly fully lowered. I'm not sure OSHA would approve, but they're not around... /forums/images/graemlins/shocked.gif
OSHA or no, be careful on those slopes.
-otus
UNUSED FUTURE MINI SKID STEER STRAIGHT DIGGING ARM (A51244)
UNUSED FUTURE MINI...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
Grasshopper 722D Zero Turn Mower (A50514)
Grasshopper 722D...
