BX24 vs B21 TLB ?
   / BX24 vs B21 TLB ? #1
miles2go
So. Oregon
Kubota L3400 HST 4WD
In order to get a sense of whether a new BX24 would suit my purposes, I'm considering renting a B21 TLB for a day and running it through the various tasks I want a tractor to do on my property.
Are there any substantial differences that a novice like myself would notice between these two tractors, aside from vintage?
In other words, if I like or dislike the B21, am I probably going to feel the same way about the BX24? Thanks!
   / BX24 vs B21 TLB ? #2
Pretty big difference between those two machines. For starters you'd be sitting a lot higher and have more ground clearance with the B21. The FEL has a lot more capacity and the backhoe considerably more power and reach. The B21 weighs in at 3850lbs which is close to double the BX series.
BX23s can be rented for the day by some Kubota dealers. The differences there would be that the BX24 would be slightly higher as it now has better ground clearance. Not sure of the FEL/BH specs on the 24 vs 23 (they are close) but you can look them up on the kubota website.
   / BX24 vs B21 TLB ? #3
</font><font color="blue" class="small">( Pretty big difference between those two machines. For starters you'd be sitting a lot higher and have more ground clearance with the B21. The FEL has a lot more capacity and the backhoe considerably more power and reach. The B21 weighs in at 3850lbs which is close to double the BX series.
BX23s can be rented for the day by some Kubota dealers. The differences there would be that the BX24 would be slightly higher as it now has better ground clearance. Not sure of the FEL/BH specs on the 24 vs 23 (they are close) but you can look them up on the kubota website. )</font>
Also you can't remove the FEL from a b21 tlb
   / BX24 vs B21 TLB ? #4
And in case you're still not completely clear regarding the differences, the BX24 is a SubCompact size (slightly bigger than a garden tractor), and the B21 is a Compact size (quite a bit larger than the Subcompact). The B21 engine is a larger displacement than the BX24 engine, and although is rated at only 21 hp compared to the BX24's 23 hp, it develops much more torque. The hydraulics on the B21 are much more powerful.
Renting the 21 hp B21 and expecting the 23 hp BX24 to be just as powerful, if not more, would be a mistake. It is in no way an apples to apples comparison.
   / BX24 vs B21 TLB ?
Thanks! guys. This is the kind of info I was after.
The B21 is still probably the closest match to the BX24 I can try out on my property, since the local Kubota dealer is not in the rental business.
   / BX24 vs B21 TLB ? #6
Many delears will let you try before you buy. I'd see if they will let you try out the Bx 24 on your property or find a dealer willing to do this.
   / BX24 vs B21 TLB ? #7
Renting a B21 is still going to be a useful experience - it will give you some insight into whether or not you will need a tractor that big or whether you can get away with something smaller. After you use the B21 you will have a good point of comparison if you can get to use a BX23 or BX24 for some period of time.
   / BX24 vs B21 TLB ? #8
Ummm ... this comparison is WAY OUT THERE. The BX24 is a SCUT ... sub-compact utility tractor. The B21 is a COMMERCIAL GRADE COMPACT TLB.
An equivalent comparison would be a 12 foot canoe and a 35 foot Searay. They are both boats but that's where the comparison stops.
   / BX24 vs B21 TLB ? #9
Apples to oranges comparison from my view point.
Attached is a photo showing a my BX2200 next to my B2910. The BX is very close in size to the BX24 and the B2910 is close in size to the B21 (same rear tires).
IF you get some experience with the B21, I would venture to guess that you will NOT be satisifed with the BX24 afterwards if you have to do much work with it.
It is just SMALLER...smaller takes longer, backhoe reach is less, digging debth is less, and so on.
Hope the picture is worth the 1,000 words it is supposed to be! /forums/images/graemlins/grin.gif
   / BX24 vs B21 TLB ? #10
I think Jim is correct if you have little tractor/TLB experience it might be worth testing the B21. Seeing what a TLB is capable of will be useful. However, I'd try to get the dealer to set up some way for you to perform a similar task with the BX24 on his lot once you've experienced the B21. As everyone has said, the B21 is a much more capable machine. Kinda like trying to assess if you'd be happy with a Ford Ranger pickup on the basis of test driving an F250.
10' Feed Bunk (A50515)
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
Gleaner R50 Combine (A50514)
Gleaner R50...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
