BX24 turn signal connector location
   / BX24 turn signal connector location #1
mpowrd
California
Kubota BX24
I've got a BX24 that has often had intermittent connections in the light switch, probably because I rarely use the lights. Usually it clears up if I cycle the switch a few times.
Now, I have a problem where the turn signals/hazard flashers don't light up at all. If I move the switch, I hear the flasher and the appropriate dash indicator(s) flash, but the lights on the ROP stay dark. This makes me suspect it's the connection to the lights and not between the switch and the flasher.
The headlights and tail lights operate normally.
Does anyone know where the lights connect to the flasher/switch? If they connect to the flasher, where is that located?
Also, does anyone have a BX24 wiring diagram they could send me via email or post a link here?
Thanks!
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A51222)
2017 CENTAURO...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
