BX24 turn signal connector location
   / BX24 turn signal connector location #1
mpowrd
Bronze Member
California
Kubota BX24
I've got a BX24 that has often had intermittent connections in the light switch, probably because I rarely use the lights. Usually it clears up if I cycle the switch a few times.
Now, I have a problem where the turn signals/hazard flashers don't light up at all. If I move the switch, I hear the flasher and the appropriate dash indicator(s) flash, but the lights on the ROP stay dark. This makes me suspect it's the connection to the lights and not between the switch and the flasher.
The headlights and tail lights operate normally.
Does anyone know where the lights connect to the flasher/switch? If they connect to the flasher, where is that located?
Also, does anyone have a BX24 wiring diagram they could send me via email or post a link here?
Thanks!
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
