BX24 Torque settings
/ BX24 Torque settings #1
dal929
Can anyone with a shop manual tell me what the torque settings are for the transmission, engine and front axles bolts are?
I failed to mention the oil drain bolts for each.
/ BX24 Torque settings #3
Hmm good question. I am not sure why you are pretty concerned unless you haven't changed oil before. i never gave it a thought to the actual torque settings for the drain plugs. Of all the years changing my own oil in various machinery (IE cars, trucks, small engines, my own BX24 etc...) i have learned to go by the feel. you never want to over tighten those bolts. i just tighten them till it stops with light pressure and then give it a little ommph tightening so it would seal against the drain plug but easy to remove next time and not ruin the threads. :)
/ BX24 Torque settings #4
Most of the torque settings are in your operating manual
I agree with figer tight then a little snug up for oil plugs
DGS
2014 FREIGHTLINER CASCADIA TRI -AXLE (A67714)
2014 FREIGHTLINER...
DYNAPAC  CP271 PNUEMATIC ROLLER(INOPERABLE) (A67714)
DYNAPAC CP271...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
Generator (A64553)
Generator (A64553)
2003 BOBCAT 331D EXCAVATOR (A65056)
2003 BOBCAT 331D...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
