BX24 Steering Wheel change
   / BX24 Steering Wheel change #1
easternhunter
Charleston, WV
Kubota BX24
Guys,
Have a BX24 that has a cracked steering wheel hub. Got a new part from Messick's. Looks the same.
Got the steering wheel nut off (7/8" socket was close enough). What kind of tool is used to get the wheel off of the shaft? No room to get anything under the steering wheel from the outside. All of the pulley pullers I have are too large.
Guidance?
Thank you,
Mike
   / BX24 Steering Wheel change #2
I don't know if this will work on your tractor or not, but on boats where I had no puller that would fit I can usually get the wheel loose by pulling back on the wheel (an extra pair of hands helps) while tapping on the end of the steering shaft with a hammer (like you're trying to knock it out of the hub.) Never caused any damage doing this, but I would thread the nut loosely back on the shaft to protect it and don't hit it so hard you peen the end.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
