BX24 stalled out under load. Now will not start. Suggestions?
   / BX24 stalled out under load. Now will not start. Suggestions? #1
tippytappy
Was plowing today so engine load was kinda heavy. Quite a bit of jostling around. Engine died, plow too deep, too much load. This has occurred many times before. What is different is tractor will not restart. No cranking. Turn the key and typical pre-start functions occur (the dashboard does it thing and the pump starts pumping) but then no starter cranking. All the cables appear to be attached. The pedals are neutral. I read in a previous post about centering the pedal. Any ideas? Can稚 find my manual. Still in storage. Thanks.
   / BX24 stalled out under load. Now will not start. Suggestions? #2
With all of the jostling my bet would be on a safety interlock having come disconnected. I don't know the tractor but maybe something like a pto switch being engaged, or the seat safety not being in the right state. Otherwise it sounds like a mostly-dead battery but with that you usually at least get a click.
The only clicking is when the key is turned to the first position, when the glow plug does it thing, the click of the pump ( I think it痴 a pump) and the gauges reset. Other than that, turning the key to the second position, when it normally will begin to crank and start, there is nothing. Will check the cables again tomorrow. Thnx.
   / BX24 stalled out under load. Now will not start. Suggestions? #4
Check all of your interlocks and cables that go to them.
Also, jostling a battery can also cause the plates weld themselves and cause a short in the battery.
I had this happen when I took a battery out of my tractor to clean the radiator. Took the cables off and the bracket. Slid the battery out, but set it down a little hard. Next thing I hear is fizzing and popping inside of the battery. Knowing what happened, I put my meter on it, and it read ~5 volts. Prior to that it was working fine. Luckily where I parked it to do work on it, I was able to slide my truck out to go to the auto parts store to buy a new battery.
Doubt that is the problem, but eh, you never know.
   / BX24 stalled out under load. Now will not start. Suggestions? #5
Since you are not even hearing a click sound when you try to start it, chances are pretty good the issue is in the safety circuit that provides the voltage to the starter solenoid, when the key is turned to the start position.
If so, the safety circuit issue could have occurred at any point after you last started the tractor, and the problem may be unrelated to the tractor stalling under load.
Try measuring voltage at the starter solenoid terminal when the key is turned to the start position. Finding no voltage there, or very low voltage, will confirm it is a safety circuit issue.
If so, you could apply 12 volts directly to the solenoid terminal and start the engine that way. Doing so could be dangerous due to possible unexpected movement of something, so you may not want to do this.
Try moving and repositioning all the levers that have contacts in the safety circuit (PTO, seat possibly, directional pedal(a second time) etc.
Since you were plowing, check the wires going to the directional pedal safety switch. Perhaps something damaged one since that area might have been closest to the ground.
Just a few thoughts...you will fix the tractor...
Added thought: you could try moving the functions that are in the safety circuit while holding the key in the start position, in case something went out of adjustment. If the starter activates while a lever is moved you will know where the problem is.
Tested the battery both with load and no load. 12V. Tested the cable connection from battery at starter solenoid also 12V.
Now, am not sure which leads to test on the solenoid.
Next to the battery cable is a wired snap connection.
There is also a thick short insulated cable between the solenoid and the starter. With a boot around the connecting end on the solenoid.
How do I post a picture here?
And I checked as many as the connections as I could see. Nothing looks different from previous.
   / BX24 stalled out under load. Now will not start. Suggestions? #8
Have you checked the voltage of the battery - preferably under load?
Here's the battery cable and the snap connection.
Here's the boot.
Not sure which one I need to check voltage on.
The battery cable to the solenoid has full voltage. So from the battery forward to this point, it's good. Things are getting very tight inside the engine compartment.
yes. the battery is fully charged.
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
