BX24 rubber lever covers
   / BX24 rubber lever covers #1
MOPAULY
Spring Mount, PA
Kubota BX24
Is it me or do these things come flying off with the least bit of gripping them to hard....it's happened to me a few times where I'm moving levers then pop off it comes and I have to stop the tractor and get off to retrieve the darn thing.
Maybe a little glue is necessary....
   / BX24 rubber lever covers #2
I had to glue one of mine, I'm sure the rest aren't far behind.
   / BX24 rubber lever covers #3
There was a previous thread about what the guys were using. I just put a little squirt of silicone caulking.
GUMBO
   / BX24 rubber lever covers #4
GUMBO said:
There was a previous thread about what the guys were using. I just...
Do what the golf pro's do - some of the thin double sided carpet tape on the clean shaft... douse with alcohol... slide the grip back on. When the alcohol evaporated the full stick of the tape returns.
   / BX24 rubber lever covers #5
fishpick gave me his tip quite a while ago and I secured them all using his recommended technique. I used very thin carpet tape. So far it has worked great.
HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT IDENTIFIER 42 (A53084)
A1 MIST SPRAYERS...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
30ft T/A Boat Trailer (A51694)
30ft T/A Boat...
20ft Shipping Container (A51573)
20ft Shipping...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
