BX24 recall or service bulletins. Help please.
   / BX24 recall or service bulletins. Help please. #1
NoviceguyInCT
CT, Litchfield County
BX24 TLB & old JD 400, JD H140
My BX24 is going in for it's 100hr service and I want to take care of all the recall and service bulletins when I'm at the dealer. I know about the seat recall (PIB-2007-027) thatnks to this site and the fender reinforcement kit service available (service bulletin # unknown).
Anyone here know the battery cover service bulletin or replacement grips bulletin number???
Is there a gage replacement service bulletin too. I can't read the hour/tach meter anylonger?
I love my BX24 but I want these minor faults repired.
Thanks !!!!!!!!!!!!!!!!
   / BX24 recall or service bulletins. Help please. #2
i am not familur with your tractor or the SB but i would just tell the dealer to fix everything service bulletin or not, you should be able to read ALL instruments on the machine.
   / BX24 recall or service bulletins. Help please. #3
NoviceguyInCT said:
... I love my BX24 but I want these minor faults repired...
NoviceGuy, here is a list that you can use to setup the next Kubota appointment with your local dealer:
Early BX24, BX1850 and BX2350 Fixes by Kubota
If you bought an early version of the recent redesigns, here are the kits to make them equal to current production:
1-Replacement battery cover frame
2-Grip Kit (Kubota part number:K2581-9557-0) Contains all the plastic handles and lever sleeves for the levers and knobs. Seems that they go on much tighter than the old ones.
3-Cluster kit: This is the dash cluster for all the gauges. The first design could accumulate moisture inside, or the hour meter may not work properly
BX1850 Part number K2501-6250-2
BX2350/24 Part number K2581-6250-2
4- Fender Kit: For the original fenders that had a tendency to break...
Part number K2581-95522
5-Step stay kit: These are the new brackets that support the floorboard. This is extremely heavy-duty. This has to eliminate any floorboard flex at all.
BX2350/1850 part number K2581-9554-0
BX24 Part number K2592-9554-0
6- Seat modification to correct ealier problem
7-HST adjustments for the abrupt reverse stop problem
   / BX24 recall or service bulletins. Help please. #4
Don't forget the new more comfortable seat.
   / BX24 recall or service bulletins. Help please. #5
((7-HST adjustments for the abrupt reverse stop problem.))
My dealer didnt know how to correct it. Is there any bulletins on it that I could refer them to. Thanks Alot.
   / BX24 recall or service bulletins. Help please. #6
My dealer said it could not be fixed.:confused:
Is there a TSB or way to fix it?
Cary:cool:
IP333 - I CAN'T THANK YOU ENOUGH FOR THIS INFORMATION !!!
   / BX24 recall or service bulletins. Help please. #8
NoviceguyInCT said:
LP333 - I CAN'T THANK YOU ENOUGH FOR THIS INFORMATION !!!
I wish I could take all the credit, however the list is based on my reading of earlier TBN posts by such fine members as Charliebrn and others.
   / BX24 recall or service bulletins. Help please. #9
Credit goes to Charliebrn and others, now I think we have the full list with numbers
1-Replacement battery cover frame- K2581-57134
6- Replacement Seat - Service Bulletin PIB-2007-027
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
Poly Round Bale Ring (A50515)
Poly Round Bale...
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
