BX24 PTO horsepower
   / BX24 PTO horsepower #1
keyman1808
Platinum Member
Freetown, MA
BX24
I believe that my BX24 has 24 horses at the rear PTO. I am looking at a PTO generator and the one I really want requires 30. Do you think it will work OK?? What say everyone.
   / BX24 PTO horsepower #2
I think we have less than 17 HP at the PTO, sorry to say. No it won't be ok, a generator requiring 30 HP will cause the BX24 engine to stall when the generator is a little over half load KW-wise.
You are right, I just looked it like 17.2. I guess that is definately out of the question then. Thanks
   / BX24 PTO horsepower #4
I doubt it has 24 PTO HP. It certainly would not be able to achieve the full output of the generator. Unless it is an incredible deal I would look for a correctly sized generator.
   / BX24 PTO horsepower #5
You can run a larger generator than your PTO HP will handle no problem, just don't load it beyond what the tractor will handle.
Might not hurt to buy a little big in case you get a more powerful tractor someday.
The common rule of thumb is about 2HP per KW...so your 17.2 PTO HP will drive a generator to about 9KW. Even if it is a 20KW generator you can still drive it with the BX just don't expect over 9KW out of it....
JOHN DEERE 1050 TRACTOR (A51247)
JOHN DEERE 1050...
2018 JOHN DEERE 5075GN LOT IDENTIFIER 91 (A53084)
2018 JOHN DEERE...
ROME GK-14 LOT IDENTIFIER 118 (A53084)
ROME GK-14 LOT...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
