BX24 PTO horsepower
   / BX24 PTO horsepower #1
keyman1808
Platinum Member
Freetown, MA
BX24
I believe that my BX24 has 24 horses at the rear PTO. I am looking at a PTO generator and the one I really want requires 30. Do you think it will work OK?? What say everyone.
   / BX24 PTO horsepower #2
I think we have less than 17 HP at the PTO, sorry to say. No it won't be ok, a generator requiring 30 HP will cause the BX24 engine to stall when the generator is a little over half load KW-wise.
You are right, I just looked it like 17.2. I guess that is definately out of the question then. Thanks
   / BX24 PTO horsepower #4
I doubt it has 24 PTO HP. It certainly would not be able to achieve the full output of the generator. Unless it is an incredible deal I would look for a correctly sized generator.
   / BX24 PTO horsepower #5
You can run a larger generator than your PTO HP will handle no problem, just don't load it beyond what the tractor will handle.
Might not hurt to buy a little big in case you get a more powerful tractor someday.
The common rule of thumb is about 2HP per KW...so your 17.2 PTO HP will drive a generator to about 9KW. Even if it is a 20KW generator you can still drive it with the BX just don't expect over 9KW out of it....
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
