BX24 PTO Chipper question?
   / BX24 PTO Chipper question? #2
The BX24 seems to run most 4" chippers just fine if the weight, and balance are within BX specs. I wouldn't hesitate to put a BX42 Wallenstein chipper on one for example though I am not familiar with the chipper you are looking at.
   / BX24 PTO Chipper question? #3
I run a Patu DC 40 chipper on my BX24. The tractor handles it fine just need to run at close to full throtle to get the 540 RPM at the pto.
   / BX24 PTO Chipper question? #4
What size is the gravely chipper? I use a Wallenstein BX-42. It is rated at 4" but really takes aroung 5". 5" will stall the tractor if the length is more than 4' or so. Under 4" it won't slow down much. The BX is rated at 17.7 pto hp. I would not try to run anything bigger than a 4.5" capacity chipper. Also remember that you should not exceed 680# on the 3 pt hitch.
Let us know how you make out.
   / BX24 PTO Chipper question? #5
I run a 4 inch on my 23.You can stall the tractor if you put a 4 inch stick in thats very long 4 ft or longer[besides i cut my wood down to about 2 inch].Other then that brush doesnt phase it.
That being said id rather have a 6 inch if i thought the 23 could get it turning.You wouldnt have to cut all the crotches up in your brush so fine,and of course wouldnt be chipping big stuff,knowing i couldnt power it.My little SALSCO does a great job,but i have to do a good job with the chain saw ,when im limbing up my firewood.
ALAN
   / BX24 PTO Chipper question? #7
boogerman2000 said:
My bx23 ran a 6 inch jinma.:cool:
AHH VERY INTERESTING:)
How did it do...any trouble getting it spinning?Mabey its time to upgrade:cool: :cool: :cool:
   / BX24 PTO Chipper question? #8
I have a 5" chipper that I use on my B7510 and have been happy with the results. The tractor has to run at PTO rpm especially when I put 4-5" pieces into the chute, but it handles it good. I know that it is borderline for my machine, but I never chip hardwood that is larger then 2" because that goes on the firewood pile. It runs fine when I feed it cedar or pine and that was the reason to get it in the first place. It is kind of ironic that we tend to look at chippers by the max capacity, but it is the small brush that is the most "in the way" and has to be chipped up.
   / BX24 PTO Chipper question? #9
My BX2350 seems to be handling the Gravely PTO Pro Chipper just fine.
It's Gravely Model 993 and is a 6" rated chipper.
I got lucky, picked it up last Monday afternoon (6-2-08) just before we got hit by storms on Wednesday and Saturday. I have already chipped up a full sized wild cherry tree.
It works really well, you should get one!
It throws chips into the next town!
71059 (A49346)
71059 (A49346)
UNUSED FUTURE 3T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 3T...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
Friesen 220 Seed Tender (A50514)
Friesen 220 Seed...
