Comparison BX24 or B2620?
/ BX24 or B2620? #1
Patrickmtrs
Dutchess Co. NY
Magnatrac Hydro 5000, Kubota RTV900 Case 580SE
Hi folks, new to the forum, but read threads often...
I'm looking for a small TLB for landscaping work I do for my customers, but it has to be light enough not to tear up the lawns. Settling on a used BX24 with 100 hours vs. a used B2620 with LA364 loader and 50 hours. I would then buy a BH77 or a woods BH80X.
I'm concerned that the BX24 may be a bit too small, any opinions thoughts?
/ BX24 or B2620? #2
From past experience, if you are a little concerned about size of BX24 I would lean towards the B2620. I think it would perform a little better in long run for light commercial use (no hydraulic fan with more hydro flow, integrated FEL valve, ground clearance, etc.) with about the same mobility in tight spaces.
Either one is light enough for dry lawns, but if you are very concerned about lawns, consider turf tires, though R4's are ok with common sense on turf.
BTW, a B2620 would require Kubota BH65 or Woods 70X BH.
/ BX24 or B2620? #3
I assume you've calculated the buying/running cost vs.
hire of equipment as required. Hope you don't buy all this
stuff , only to have little paid use in the long run ..........
/ BX24 or B2620? #4
There isn't a HUGE difference between the BX and B 20 series. More similar than different. The slightly higher hydraulic pumping power of the B would be handy. Beyond that, it's kinda all about the ground clearance difference. In the real world, the B has virtually twice the BX ground clearance. The weight difference is also rather insignificant. (oh yeah and no little fan on the B) Comes down the dollar difference, if any, I suspect.
/ BX24 or B2620? #5
Owned several of both and couldn't have said it any better myself.
Did a side by side review with pictures in the past of a BX2660 and B3200. Two biggest of each series at the time. Ground clearance and slightly bigger bucket was the main difference.
I guess if I was going for paid production I'd go for the one with the biggest bucket and most power since I'd be in a bigger hurry to get all jobs done. Time is money.
/ BX24 or B2620? #6
I would go with the 2620. I personally bought a BX25 in 09 and upgraded to the B3200 this past July because I wanted that extra weight and power. If I would have went with the B2620 in 09 I would have been happy with that purchase and not felt the need to upgrade. Like I read once, figure out what you want and go one size bigger. :D
/ BX24 or B2620? #7
I subscribe to the theory of buy the one you think will best meet your needs. If after a year your needs have changed or it doesn't meet your needs (to big or to little and I've done both) fess up to your mistake and trade for another one that you think is really the RIGHT one.:laughing: Guess that's why I've visited Barlows 13 times and left with a new debt contract (one of those will be paid off in Dec 2011:)) with Kubota. I still have 5 Kubotas so they all haven't been mistakes and some of them met my needs at the time and then my needs changed.
My theory may cost a bit more money but maybe it will relieve some of the mental distress caused by worrying over making a mistake.:) OK some will say the extra debt causes more mental distress but that ain't so for all of us.:)
/ BX24 or B2620? #8
I personally would opt for the B2620. Like mentioned before, get the bigger tractor and you will likely end up having the right one vs. trading up in the future. :)
/ BX24 or B2620? #9
To me the only choice is the B2620 with a Kubota backhoe! Not the woods.
/ BX24 or B2620? #10
I have a 2920 and it doesn't tear up the grass in 2 wd,,, the lawn adapts to the 4wd after a few mows, I use r4's
/ BX24 or B2620?
Thanks! You guys/gals are great! It really helps to flesh out your thoughts with those who have been there/done that. I am confident that the BX24 will do the job, but I am just as convinced that the 2620 will do that job and more. I appreciate the feedback. Now... what about the ZD331? I'll post later... :)
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
Year: 2019 Make: Freightliner Model: B2 Vehicle Type: Bus Mileage: Plate: Body Type: Conventional (A59230)
Year: 2019 Make...
2007 Mercedes Benz -S550 AWD Sedan (A59231)
2007 Mercedes Benz...
