BX24 leaking from transmission seal
   / BX24 leaking from transmission seal #1
douce48
CT
Kubota BX24
I brought my BX24 in to the shop after going to replace the transmission oil and noticing leakage all around the tranny and on top of my skid plate.
(Never saw the leakage because of the skid plate)
They haven't started working on it yet but says to becoming from the oil seal behind the HST cooling fan - the area I bought the skid plate for to protect :mad:
The mechanic said in all his years, he has never seen one of these fail with so little hours, 397hrs., figures.
> Anyone else have or hear of this issue?
   / BX24 leaking from transmission seal #2
No I havent . I have over 500 hrs on mine.
   / BX24 leaking from transmission seal #3
Haven't heard of this either. I have almost 500 hours on mine, nothing like that (knock wood.)
   / BX24 leaking from transmission seal #4
I'm not sure the skid plate would stop a seal failure. Did they say it looked like there was some type of blunt force impact that caused the problem?
I put the skid plate there to protect the HST fan from getting broken. I'm going to call today to find out what is causing the leaking. Can't be damage. It (stick, branch) would have to trough the fan first.
Very expensive seal (labor) if it is leaking from there.
Mechanic says the HST shaft is actually worn. Mechanic says he hates to say it, but it looks like a defect. First time ever that he's seen this.
Needless to say, need new $haft, bearing$ and oil $eal and about 10 hour$ labor. I wonder if they make a steel HST fan I could put on while it's down so I don't have to go back for that someday?
Douce
   / BX24 leaking from transmission seal #7
Although I've read about sticks getting past the Bro-tek shields, I think it's unlikely. Have you got both front and back shields? I really felt the rear alone was a waste of time. Front and back give you full coverage. I did a lot of reading and thinking about this after my fan got ate. If I somehow lost my current fan, I'd definitely consider some of the alternatives presented on this forum.
Irrigation Pump (A52128)
Irrigation Pump...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2002 Sterling M7500 Acterra Lift-All LA04C51-15 Insulated Forestry Bucket Truck (A50323)
2002 Sterling...
