BX24 HST Dip Stick Blew Out
   / BX24 HST Dip Stick Blew Out #21
I had the same thing happen to my BX24...just happened to see it laying in the dirt and thought ...WHAT is THAT!?!
I cleaned it off and put it back in , and it`s not done it again.:thumbsup:
Thanks, your post helps relieve my worry. Others mentioned that it probably wouldn't happen again but hearing it from someone that it's actually happened to helps. I think I keep my "idiot cord" attached to the dip stick for awhile just in case.
   / BX24 HST Dip Stick Blew Out #23
re "vacuum" ...if your vent is clogged and your dipstick o-ring is a tight fit, wouldn't you generate a slight vacuum as you pulled it out?
   / BX24 HST Dip Stick Blew Out #24
Now that I know that the dipstick is much larger than on mine, it could take much less pressure to blow it out.
As far as I know, about the most replacement flow you can generate is if you had all the cylinder rods extended, and then you retracted them all as quickly as possible. This would be like if you had the bucket all the way up, and the bucket curled, and then you simultaineously lowered the bucket, and curled the bucket back up at the same time. You could even involve the 3pt in this game (Lift is up, and lowered at the same time the FEL boom is dropped, for example.)
If I am right, the oil level in the sump has to rise the amount of the volume of the cylinder rods (but for the 3pt, which will be the entire bore volume .) That is not an inconsiderable amount of air displacement.
Maybe a test: Raise the bucket fully, perhaps with a little weight in it. Pull the dipstick to relieve any air pressure/vacuum. Put the stick back in, and then lower quickly. (could put a little bubble water on the vent before the lower.)
If the stick stays in, pull it out, and see if it comes out with a pressure assist.
If it doesn't come out on its own, and if when you pull it out, you do not hear a pop, or the stick does not come out extra easy due to pressure, then so far as I know, the vent is serving its purpose.
Thanks for the troubleshooting steps, I'm printing it off now and will give it a try this weekend. I wasn't expecting such a thought out reply and I really appreciate it!!
I tried EE Bota's troubleshooting steps today along with trying the same manuever that I think caused the dip stick to blow out and couldn't reproduce it. I will leave my "idiot cord" attached to the HST dip stick for now and keep on working it. As other have mentioned, it probably will never happen again. Thanks for everyone's help.
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
UNUSED AGT INDUSTRIAL SDA-140W LOADER (A51243)
UNUSED AGT...
JLG 800A MANLIFT TELESCOPIC/SCISSOR BOOM (A51242)
JLG 800A MANLIFT...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
