BX24 HST Dip Stick Blew Out
   / BX24 HST Dip Stick Blew Out #11
Has the vent actually been checked? On my B1550 the vent was plugged not with dirt but just a poor design. It would push oil out the dipstick untill I fixed the vent. Make sure your vent is open.:thumbsup::thumbsup::thumbsup:
   / BX24 HST Dip Stick Blew Out #12
I'm not 100% sure on this, but isn't the dipstick just in the sump part of the hydraulic system? Meaning it isn't really under any pressure from the pump? If so, I agree, just a one time fluke most likely.
Thanks again for all the comments. Hopefully this was a one time issue and never happen again. Without the FEL on yesterday, I mowed and dragged 3 acres of pasture without any issues.
kuboman - No, the vent hasn't actually been checked because I really don't know how to. All I see is a red cap over what I was told is the vent/breather. When I get home tonight, I will see if I can pull the cap off and see what's underneath. I do know that there isn't any fluid around the breather.
dodge man - I would agree that this doesn't sound possible but I do know that there is quite a bit of vacuum pressure when I remove the dip stick. Maybe I didn't really seat the dip stick properly when I last checked it but I don't think so. I'm pretty **** about that plus the location of where I found the dip stick.
   / BX24 HST Dip Stick Blew Out #14
If you have a vacuum, your vent is clogged. If you ever have a pressure, your vent is clogged.
I know I have some fuel hose, and I would press that over the dip stick hole, and blow...and should be able to hear air escaping from the vent, but failing that, you should not actually be able to pressurize the system.
I presume the vacuum you think you feel is the rubber of the dipstick snagging. It you truly do have a vaccuum, it seems to me your vent MUST be clogged.
Dodgeman is right, the stick is in the sump (actually right high up) and there is no reason for pressure (including negative pressure: vacuum) to ever build there if the vent is working properly.
You are on track...make sure that vent is not clogged like you plan, and you will be home free. I don't know how to take the red thingy off. If the entire device can be screwed out, I would leave the red cap alone, and remove the entire vent.
(My BX2200 is bound to be slightly different, else I would be more helpful.)
Thanks again for helping me out. You are probably correct that I don't have a vacuum going on, what I am really feeling is the rubber oring snagging. It can really give the perception of vacuum. The next time I get the tractor up to temperature, I'll shut down and check it again more carefully.
For now, I have struck out on checking the vent/breather. I carefully attempted to pull up on the red cover but it didn't budge. I don't want to screw anything up by doing something wrong. I also don't see a way to screw it out but I will try to figure it out. I'm going to go through my WSM one more time to see if I can see a reference to it.
   / BX24 HST Dip Stick Blew Out #16
Looking at the parts diagram it appears the breather is just poked into a rubber grommet. Kubota calls the part it is inserted into a "bush"..??
So it should pull out...just a guess.
Thanks Skyco. I just looked at my parts manual and now see the same thing. Since there is no reference to it in the WSM, I'm not going to take a chance on messing something up by trying to take it out. I'm going to go by the dealer this weekend and ask them how it is removed. By being there, hopefully they will show me how it's done on one of their tractors.
   / BX24 HST Dip Stick Blew Out #18
Couldn't you just make sure the vent is working by preparing a small hose (or perhaps a soda straw) and some bubble water, and while blowing (with your mouth) through the hose into the dip stick hole, brush a little soapy water on the vent? If the vent is working, there is no need to remove it. I wouldn't be seeking to remove it unless I knew it was clogged. That's just me, a notorious fraidy cat. I can hear you all chanting "fraidy cat...fraidy cat...fraidy cat."
I totally agree with you on being a fraidy cat, I'm this way too when it comes to something I don't know about.
I saw in your previous post about blowing air into the dip stick hole, I wasn't ignoring the suggestion, just haven't tried it yet. Not sure how well it will work since the dip stick hole is at least 1" wide. If it was the oil dip stick I could see this working better. I'll give it a shot.
   / BX24 HST Dip Stick Blew Out #20
My ignorance is showing. I presumed yours was like mine, and I am wrong. It will take a bigger hose than I normally have around. Sorry about that.
TRAILER AXLE (A51244)
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
