WilliamBos
Super Member
- Joined
- May 1, 2004
- Messages
- 5,373
- Location
- Innisfil, Ontario, Canada
- Tractor
- MF 1635 12x12 Powershuttle
As some here know, I am involved in an industry that repairs vehicles and have actuarial statistics on breakdowns as well as COF (cause of failure). I could go on for pages on the problems with Fram filters. That doesn't mean that someone won't come on and say that they've used Fram filters for XX years with no problems. As far as that goes, an old college buddy has a Chevy Chevette that has over 200k miles on it and feels as if it is one of the best cars ever made. I have a 1962 Chevy Biscayne with 100k miles on it and it never came with any sort of oil filter and never had one on it! It still runs fine. Does that mean engines don't need any oil filter? Same logic.
The fact is Fram makes the least expensive filters. Besides filtering, there are valves inside the filters that must perform correctly such as a valve to prevent flow back (keeps from having all the oil flow back down out of the upper engine) and a bypass valve (allows oil flow when the filter element is clogged. Both of these valves are considered "unacceptable" in Fram filters. Also the oil flow of a filter is very important. If you have a very small micron filter element (traps smaller particles), it must have a far larger surface area or it restricts oil flow. If you have a small surface area of the filter membrane (like on Fram), the filter element allows larger particles to pass through. Finally, there is the actual can itself. I can crush Fram filters with my hands like a soda can. If that filter is struck by a stick or rock etc., it is much more likely to break than other brand filters. Also, I have had two Fram filters blow their can apart when I used to use them. One was on a VW Baja Bug. I missed a gear and redlined the tach and the Fram can sort of exploded. Again, I could go on for page after page of similar Fram problems but I see no need.
I'm definitely in the camp of people who wouldn't touch anything with the Fram name on it. I have nothing with an engine that I consider worthless or disposable. There are plenty of quality filters from Baldwin, Donaldson, Wix etc. that are readily available and made far better than Fram. I'll summarize what statistics tells me about Fram filters; Fram filters are trash. But, it's your equipment. What is your equipment worth to you? If you feel it's worth risking your equipment to save a couple of bucks, that's your choice.
Double AMEN to that!!
