BX24 Fender Issue - Fixed!!!
/ BX24 Fender Issue - Fixed!!! #21
MOPAULY said:
Interesting. I will call my dealer tomorrow and see what they have to say. My fenders are not cracked but it would be nice to have the additional supports.
Is this fix available from the dealer for free? Will they install this for free? I have BX24 with the old fenders, but they are not cracked.
Thanks for all your help.
I just got my BX24, and the dealer had no idea of the fender issue. He actually argued with me that I was confusing the BX24 with a different model. After emailing him pictures from this fine forum, he called Kubota and they had the brace kit within two days. From the way he made it sound Kubota wasn't going to issuing a recall. At minimum your dealer should get you the kit for no cost. Its only a few bolts, so installation isn't really an issue.
/ BX24 Fender Issue - Fixed!!! #23
kubotalinc said:
where does the fender crack
My broke the other day on my BX2350. According to my dealer, it is generally on the left side. They have ordered the parts and it is covered under warranty. If you don't mount /dismount on the left side it may not happen to you. I almost always use the right side but the other day I went to step up on the left and...crack!!
Terry
/ BX24 Fender Issue - Fixed!!! #24
kevinj said:
.... That will fix all my issues except the horrid reverse stop issue which I understand they are working on.
Can you tell us more about this problem please?
/ BX24 Fender Issue - Fixed!!! #25
Do a search as this has been discussed to great lengths.
I have no more info at this time, when my dealer has the fix he will let me know.
/ BX24 Fender Issue - Fixed!!! #26
The issue is that in reverse, the tractor will stop very abruptly when you let go of the pedal. Actually, it was designed that way due to some lawsuit, and it is also being seen in other brand tractors as well. From what I gather, there is enough customer clatter about it that kubota may be designing some way of softening up that stop somehow. I hope so, it is an awful quick stop, it'll snap your head back if you're not prepared for it. It is mainly in high gear and only in reverse that you get this, going forward is fine. I must say that I've learned to feather the reverse enough to help, but it still catches me off guard sometimes.
/ BX24 Fender Issue - Fixed!!! #27
I haven't noticed that on my 7800, it does stop faster in reverse than forward but not to the extent that it snaps my neck. Funny they would do that for one tractor and not the other models? Extra weight maybe? Stupid lawsuits.... I'm surprised they still let you start the thing without the seatbelt fastened!!! :mad:
/ BX24 Fender Issue - Fixed!!! #28
From what I gathered it's mainly in the new tractors designed for "homeowner use" whatever that means...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
2018 Frontier RC2060 (A64126)
2018 Frontier...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
