BX24 Fender Fix Serial Number
   / BX24 Fender Fix Serial Number #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Hi group. Does anyone happen to know what serial number (and up) on the BX24s are the ones with the fix for the often-cracked fender? Or, if not, how can I identify a BX that has the fix in place? Do the ones that come from the factory already fixed just have the same bracket that they offered to the already-sold BX's with this problem?
Thank you!
   / BX24 Fender Fix Serial Number #2
You have to look underneath to see the new support ribs molded into the plastic. Here is a photo of my old and new fenders. There are about
4 thin plastic ribs on each side.
Excellent! That picture is very helpful. Thanks a lot Singlecoil.
   / BX24 Fender Fix Serial Number #4
There is also a Bracket which goes under the fender for support. The new Tractors come with this installed, The older ones do not. Your dealer will provide at no cost the fix
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
