Oil & Fuel BX24 engine stalling out, or coming close to it
   / BX24 engine stalling out, or coming close to it #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
My BX24 has started to no longer run perfectly. The engine starts running as though it is starving for fuel, usually when it's under a load such as driving into a pile of dirt, but not always. It seems that it also happens when I'm on a slope, sideways. I'm not talking about the normal laboring that it does when you're demanding more power; it's much more severe than that.
Based on its behavior, the first suspect was the fuel filter. I replaced that, but it still does it. I cleaned the air filter (Kubota dealer was closed today, so I couldn't get a new one - will do that next), but that also had no effect. Here are the other things I intend to try to cure this, probably in this order:
1. Replace the air filter. I expect this to do nothing.
2. Dump some injector cleaner into the tank. I expect this to do nothing.
3. Change to a different brand of fuel. I expect to do nothing.
4. Replace the fuel pump. If I do this, I hope that does something!
Any other suggestions on what to do here? I have large piles of dirt all over my front yard that are a little hard to move with the tractor sputtering when I try to get a scoop.
Thank you
   / BX24 engine stalling out, or coming close to it #2
Ray, it is a fuel problem You might have junk in the tank.
From reading another thread, I learned that there is a second fuel filter. This answers the other thing I was wondering about today, in how it didn't make sense that the fuel filter came further down the line than the pump, when I thought there was just the one filter. So, I just went out and replaced the other filter. I do believe that was the culprit. I'll keep my fingers crossed as I sleep and test it out in the daylight.
   / BX24 engine stalling out, or coming close to it #4
sounds like feul issue for sure. Hopefully the second filter will solv eyour issues. Which one did you replace already ? the one underneath the BX or near engine ? Hopefully you haven't replaced the one underneath so when you go to replace the filter, I would take compressed air and blow the line back into the tank to make sure the tank inlet is not blocked.
Yes, it was the one underneath that I had not replaced. I replaced it last night, and then took a shower to rinse the diesel fuel off me that I wound up lying in. Is there really no fuel shut off from the tank? That's messed up, if so. I clamped the hose as best as I could, but I still wound up becoming a flammable person.
Just to follow up, I finally got some rain-free daylight to test the tractor out after replacing the second fuel filter, and it's back to running right again. Thank y'all.
   / BX24 engine stalling out, or coming close to it #7
I have a BX24 that does the same thing, on mine it is not the filter, usually when mine starts acting up I take the rubber line apart from the tank side of the filter and blow it back into the tank with a air hose blowgun, WARNING take the fuel tank cap off before you do this or you will smell lovely. I have a end that goes into my blowgun that will go into the rubber line and I use a vice grip to pinch the line closed
   / BX24 engine stalling out, or coming close to it #8
awesome rayco! glad you got it fixed.
Thank you.
   / BX24 engine stalling out, or coming close to it #10
are you in low range or high? these tractors dont have much power in high range
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
6 Trench attachment (A50322)
6 Trench...
