BX24 engine rpm for proper pto speed
   / BX24 engine rpm for proper pto speed #1
Dick Calland
south eastern Wisconsin
Cub Cadet 7532, Kubota BX24, Ford 9N, Oliver 70
I purchased a BX24 in June, 2008, but did not buy the mid-mount mower until 10/3/11. After a review of the PTO section of the owner's manual, I did not find a Kubota recommendation for engine rpm to bring the rear pto to 540 rpm or the mid pto to the 2500 rpm speed. If someone has found a Kubota recommendation for appropriate engine rpm, can you please tell me where to find this ?
   / BX24 engine rpm for proper pto speed #2
I think the actual number is somewhere between 3000 and 3100 RPM, but I recommend you run it wide open throttle for everything.
   / BX24 engine rpm for proper pto speed #3
I thought I read it was 3200 RPM in my book. I run mine between 3000- and 3100 for both mowing and blowing snow. Seems to really like it there.
   / BX24 engine rpm for proper pto speed #4
I run mine wide open for mowing. If the grass is really dry or not very thick, I will sometimes back it down to 3100 rpm or so.
   / BX24 engine rpm for proper pto speed #5
from page 2 of operator's manual under specification under pto section says:
rear pto= 540 rpm at 3142 engine rpm
mid pto= 2500 rpm at 3043 engine rpm.
I find that running at 2600-2900 (preferably 2850) gives me good performance. When I get into thick/tall grass or alot of clippings to move, I just bump it up to 3200 rpms and it will drop a little bit and vary around 3000 rpms or so when running into the thick/heavy stuff.
2014 JOHN DEERE 17D EXCAVATOR (A51242)
2014 JOHN DEERE...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51242)
2012 VOLVO A40F...
6' King Kutter 3 pt Disk (A50515)
6' King Kutter 3...
