BX24 Differential Lock........
   / BX24 Differential Lock........ #11
I found numerous other diagrams in the service manual and the preponderance of them shows the arm in the up position...so apparently mine is correct.
Next step is to jack the rear end off the ground, remove the pedal linkage and move the arm by hand while rotating the rear wheels back and forth. Which should accomplish what you did by turning the steering wheel. I would imagine I can get a feel for what's wrong by how the arm feels. If I have to move the arm farther than allowed by the pedal to get it to lock then I can assume either the shift fork or the pedal linkages is bent. If I can't get it to lock at all I can assume the shift fork is broken, or the shaft/fork pin is broken or has some out. Would have been nice if they put a shear pin in the linkage to prevent over stressing the shift fork.
JohnnyB
6-row Tine Cultivator (A52128)
6-row Tine...
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A51242)
2017 CATERPILLAR...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2016 Ford Explorer...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
Dodge Charger (A50324)
