BX24 Brush Cutter
   / BX24 Brush Cutter #1
Wayne's Train
Has anyone had any experience with an LMC clipper 400? It looks like a good match for my tractor without FEL as ballast.
   / BX24 Brush Cutter #2
WAYNE'S TRAIN, I BOUGHT THIS SAME CLIPPER THIS PAST WEEKEND FOR MY BX 2660 AND IT WORKS GREAT. I TURNED THE PINS IN SO LIFT ARMS WEREN'T SPREAD SO WIDE. TRACTOR HANDLES THE WEIGHT OF CUTTER FINE.
TIM
   / BX24 Brush Cutter
Congrats on the new cutter. Good to hear it's working out. I've got a 54" mmm now and it works great but I'm lining up some large lawn and pasture work for this season so I've got to get a brush cutter. I cut a 2 acre pasture grass lot with it. The grass was 2-3 feet or more. It took 4 passes to get it down to lawn level. Is the 2660 about the same size as a BX 24? Thanks for the reply. Any pics?
   / BX24 Brush Cutter
The LMC website says this one is for grass only. Does that mean you can't take out light brush or small saplings? A dealer told me that the 400 has an italian gear box that is better/stronger than the ones LMC uses on the bigger models.
TMA (A49461)
TMA (A49461)
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
