bx24 bent bucket curl piston
   / bx24 bent bucket curl piston #1
timalabim
I was pulling a big stump and must have caught the bucket under a couple of roots I was trying to scrape the dirt off of. I noticed I couldnt uncurl the bucket all the way. I checked it out and sure enough I bent the piston shaft for the bucket curl. Tractor is just about 2 years old. Any chance of warranty coverage for this type of incident? If not, how much should I expect the repair to cost?
   / bx24 bent bucket curl piston #2
Bummer!
Do you have any pictures?
I would guess that it wouldn't be covered and that your cheapest option would be to buy a generic cylinder that meets the specs of the Kubota one.
   / bx24 bent bucket curl piston #3
That sucks....at least it should be an easy fix beyond the cost of the cylinder.
A bit off topic...
I was moving some rocks the other day...One was under a tree with low branches... I couldn't get it with the BH thumb (it was to big) and I couldn't scoop it up with the FEL so I used the FEL bucket in front of the rock and dragged it back into the open where I could get a better angle to scoop it up. It worked and the FEL had just enough power to lift it. I wondered if pulling it backward with the bucket was a smart move as I don't think its engineered for loads from the back...any thoughts about that?
yeah, sure does suck.
Anyone know the part number, price? Can't find much online for parts lookup
it is a BT601 BH Bucket Curl Cylinder
   / bx24 bent bucket curl piston #5
Take the cylinder off. Bring it to a local hyd shop. They can buy the blank chrome rod and machine it. Definately check Kubota's price. Sometimes it is just as cost effective to buy from the dealer. I don't know what diameter your rod is, but just for an example, 40mm rod (about 1.5") is about $3 an inch. I'm going to guess that a bucket cylinder is closer to 25mm, or about 1 inch o.d. 25mm is about $2.25 per inch. Then, tack on for machining and a seal kit.
thanks guys,
I knew I could count on TBN for sympathy and support.
   / bx24 bent bucket curl piston #8
Before you buy a new one try going to the local hydraulic shop to see if it can be straightened. It sounds like a small bend, if it can be straightened I would guess that would be the cheapest option.
   / bx24 bent bucket curl piston #10
golfbum said:
The list price for the rod from Kubota is $158.72.
Not too bad all things considering, I'd go new for that price!
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
