Backhoe BX24 backhoe thumb custom made PICS
   / BX24 backhoe thumb custom made PICS #1
IC Smoke
PITTSFORD, MI
Kubota B2400, ZD28, BX24
Custom fabricated thumb! welded piping thru the boom so it would help the rigidity of the boom. 2 pins and the thumb comes off!
I used it for about a hour moving brush around, moving railroad ties, small logs and just plane messing around.
I was able to dig with the thumb attached but I couldnt reach out to dig but you could still do a trench or hole just a little bit tricky.
NOTE* the orange paint I used was factory KUBOTA paint from the dealer, Ill have to find some paint that matches perfectly.
PICS*
Hope this gives some ideas!!!
Ian
   / BX24 backhoe thumb custom made PICS #2
Excellent work!
Singlecoil said:
That thing looks STOUT!
Its a brute! Ive been messing with it the past week moving scrap steel around, digging out a few large bushes and just beating the crap out of it! I did pick the tractor up in the air with the thumb on the ground only, still held and no issues with the boom. I just wish the tractor was a little bit bigger.... Ill have to save my pennies for the L39;)
   / BX24 backhoe thumb custom made PICS #5
Nice job on the thumb. Looks heavy duty. To make it more versatile, you could modify it to fold back.
   / BX24 backhoe thumb custom made PICS #6
Wow that does look stout! I made one too but I didn't have the cajones to bore through the dipper stick, warranty issues and all :p
BTW you may find you want to make its angle adjustable, I've moved mine in and out quite a bit depending on what I'm picking up.
I'll get around to posting my pics ...someday:rolleyes:
   / BX24 backhoe thumb custom made PICS #7
that thumb is going to be thicker then any other single part on your tractor....just a little overkill there.
   / BX24 backhoe thumb custom made PICS #8
That steel looks like 1 X 3 in stock. Is it A36 or T1, and is that laser cut or plasma cut?
   / BX24 backhoe thumb custom made PICS #9
IC Smoke,
Welcome to the TBN. I am also a member of the TDR and have 2001 Cummins. Read many of your posts over there. My blood runs Diesel.
Cary:cool:
Cap-n-Cray said:
IC Smoke,
Cary:cool:
Best setup around, Cummins and Kubota! best of both diesel motors!!!!
Ian "IC Smoke"
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2018 JGL 2632ES 26FT Scissor Lift (A50322)
2018 JGL 2632ES...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
