Backhoe BX24 backhoe thumb custom made PICS
   / BX24 backhoe thumb custom made PICS #1
IC Smoke
PITTSFORD, MI
Kubota B2400, ZD28, BX24
Custom fabricated thumb! welded piping thru the boom so it would help the rigidity of the boom. 2 pins and the thumb comes off!
I used it for about a hour moving brush around, moving railroad ties, small logs and just plane messing around.
I was able to dig with the thumb attached but I couldnt reach out to dig but you could still do a trench or hole just a little bit tricky.
NOTE* the orange paint I used was factory KUBOTA paint from the dealer, Ill have to find some paint that matches perfectly.
PICS*
Hope this gives some ideas!!!
Ian
   / BX24 backhoe thumb custom made PICS #2
Excellent work!
Singlecoil said:
That thing looks STOUT!
Its a brute! Ive been messing with it the past week moving scrap steel around, digging out a few large bushes and just beating the crap out of it! I did pick the tractor up in the air with the thumb on the ground only, still held and no issues with the boom. I just wish the tractor was a little bit bigger.... Ill have to save my pennies for the L39;)
   / BX24 backhoe thumb custom made PICS #5
Nice job on the thumb. Looks heavy duty. To make it more versatile, you could modify it to fold back.
   / BX24 backhoe thumb custom made PICS #6
Wow that does look stout! I made one too but I didn't have the cajones to bore through the dipper stick, warranty issues and all :p
BTW you may find you want to make its angle adjustable, I've moved mine in and out quite a bit depending on what I'm picking up.
I'll get around to posting my pics ...someday:rolleyes:
   / BX24 backhoe thumb custom made PICS #7
that thumb is going to be thicker then any other single part on your tractor....just a little overkill there.
   / BX24 backhoe thumb custom made PICS #8
That steel looks like 1 X 3 in stock. Is it A36 or T1, and is that laser cut or plasma cut?
   / BX24 backhoe thumb custom made PICS #9
IC Smoke,
Welcome to the TBN. I am also a member of the TDR and have 2001 Cummins. Read many of your posts over there. My blood runs Diesel.
Cary:cool:
Cap-n-Cray said:
IC Smoke,
Cary:cool:
Best setup around, Cummins and Kubota! best of both diesel motors!!!!
Ian "IC Smoke"
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A49461)
2015 Peterbilt 579...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
John Deere 455G Loader (A48837)
John Deere 455G...
