Backhoe BX24 Backhoe removal question
   / BX24 Backhoe removal question #1
Cherokee180
Kubota BX24
I am getting ready to use my 3 point hitch with a rototiller soon so I thought I would practice the BH removal. After watching all the video, reading the manual, I was ready.
I went out tonight, hoisted it with the dipper and.....one pin comes right out, the other won't budge. I dropped it back on the tires and the tight pin comes right out, but the other one is tight.
This is nothing like how easy it looked on the video's. What am I doing wrong (nice level concrete driveway). Even sprayed them with breakfree and tapped on the tight one with a hammer and it won't budge, so for some reason, it must be binding. Does it create a problem to remove one pin on the ground, the other in the air?
Thanks all....Jeff
   / BX24 Backhoe removal question #2
I had the same issue bx23 and I don't know the last time it came off. So I had to persuade it with lube and a hammer and since then it has not been an issue. Comes off every time easy.
   / BX24 Backhoe removal question #3
I noticed there been some complaints about the pin on the left side on BX24 being stuck. I know- I am one of them. I had to clean paint off from the holes. Since its new for you, you may need to have your outriggers down and use it in slightly up or down to twist frame a bit to get the pin out on the left side.
Good to know. I bought it used, and the pin moved freely on the left when it was on the ground, so I figured the backhoe lifting was just putting a bind in it. I am thinking that removing the left pin first, then hoisting it up on the BH to pull the right one out shouldn't be an issue since it isn't supporting anything (if it is coming out freely anyway). Using the outriggers is a good idea too.
Another thought I had is that my driveway has a very slight incline, so perhaps when I lifted it with the BH it was rolling forward enough to create the bind on one side.
   / BX24 Backhoe removal question #5
Make sure you have the pin in so the hoe is centered and not swung a little to one side. It can fall without the pin in and it will also bind. Try using the stabilizers to tweak it a little and it will come right out. Clean and grease the hole where the pin goes before you put it back in.
   / BX24 Backhoe removal question #6
When I had my BX24, I would remove and re-install the Backhoe probably 4-6 times a season. I actually got pretty good with it even if I do say so myself. :D
Anyway, I wanted to mention that using the stabilizer controls and stabilizers to shift the BH just enough to align the holes for the pins. Very small movements will often times release the tension on the pin. Watch the pins and you can see the tension coming off them as you manipulate the stabilizers as well the the boom.:thumbsup:
Once done, it's a real easy task. Slick as snot with a little WD40 sprayed on the pins a couple times a year. :laughing:
   / BX24 Backhoe removal question #7
I have a BX25 and I to was concerned about removing and reinstalling the BH when I need to use the tiller, Boxblade or Overseeder. I have found the easiest solution, a bit more expensive but much easier. Bought a B2320 for 3ph work. Get it tomorrow.:)
   / BX24 Backhoe removal question #8
What I have found is to use the stabilizers to shift the BH around like Mounted Madness suggests. It actually takes me longer to put the 3pt linkage back on.
   / BX24 Backhoe removal question #9
yup .. I can attest to that !!:D:laughing:
   / BX24 Backhoe removal question #10
You mentioned that the tractor was rolling forward, did you push down the fel to raise the front wheels off the ground... this actually helps to level the frame which is ultimately important to reduce flex causing the binding.
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
3014 (A50657)
3014 (A50657)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
