Backhoe BX24 backhoe relief valves
   / BX24 backhoe relief valves #1
ACHINBAC
Middleborough, Ma
BX24
Does anyone have a work shop manual for the BX?
I recently bumped the main relief valve to 2000psi as measured at the FEL QDs and got what appears to be a decent bump in capacity (see recent post in customization). However, In going through the parts diagram for the backhoe valve assembly I noticed 3 relief valves - if they are set lower than 2000psi I wouldn't get the full benefit of the additional pressure while hoeing.
Does the manual describe the factory settings for these valves?
Thank's
Dave
   / BX24 backhoe relief valves #2
They could be shock-relief valves. You should find those on a work port,
not on the main valve body. Don't mess with them, if they can be adjusted
at all.
   / BX24 backhoe relief valves #3
ACHINBAC,
There is only the tractor system relief set at 1778-1849 PSI on both the loader and backhoe.
dfkrug is correct that the reliefs on the backhoe are overload reliefs - used to protect the weldments from being overloaded as opposed to a circuit relief valve.
FYI the on BX hydraulic circuit, the backhoe is fed first and then the loader so the system RV is downstream at the loader will see the backhoe pressure.
Don't dial in too much "extra lift capacity" or you will break something!
Good luck!
Yankee & Krug,
Thank's for the head's up & by the way, if something breaks, this forum will be the first to know.
Now an update: (long story) Last fall I got stuck in a poop pit helping the neighbors flatten out an area where they dump the horse stalls - at one point I extended the hoe straight out to grab and pull me out, or to try & reposition the rear wheels (was up to the axles at that point) down pressure on the boom failed and could not lift the tractor. Got out eventually. An hour ago I took the tractor out to see how the new front struts work & for grins set the FEL down, lifted the front wheels, extended the backhoe all the way out, and the boom picked the tractor up easily (pics later). It appears the boost on the relief valve works on the backhoe as well as the FEL.
For the few times I need the extra juice, the upgrade is worth the risk (for me)
Dave
Can get out of any hole now . .
   / BX24 backhoe relief valves #6
Love the picture. For some reason that is just too cool. Either for changing tires or the profile lights, I am not sure, but definately too cool. This will take a couple Friday night Cocktails to decide...........
Early next week I will aslo be tweaking the paramaters on mine.
Coming in for a landing. . .Parameters must be tweaked . . . .
   / BX24 backhoe relief valves #8
Man your tractor is on steroids, is that legal? look at it flexing it's muscle:cool:
It's like your in a tractor show, you should rub baby oil all over it,
Kinda Looks like those rims are waxed to me,
Theres no fur on em' thats for sure. Wish I could dowload a video for you guys - had that sucka bouncin' fi maybe six feet in da air . .
   / BX24 backhoe relief valves #10
I like the underside blue lights Too!!! adds just the right touch. I was told by someone to take a heat gun and remove my reflector stickers, I guess you didn't get the memo. just kidding. Don't you dare take them off they look good .
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
International 806 2wd Tractor (A52128)
International 806...
Chisel Plow with Cultivator Sweeps (A52128)
Chisel Plow with...
UNUSED AGT QUICK ATTACH FLAIL MOWER (A51244)
UNUSED AGT QUICK...
