Bx24 aux lighting switches
   / Bx24 aux lighting switches #1
cubowner
Kubota BX24
Hey all I'm about to add some aux work lights to my bx24. I need some advice on where to put the switches for the lights. The dash is kind of crowded, any ideas or thoughts would be great.
   / Bx24 aux lighting switches #2
perhaps u may invesigate using auxilary power socket just to rigtht of seat.
Already using that port I have the kubota rear work light.
   / Bx24 aux lighting switches #4
I'm not that familiar with the BX layouts as I have a B-series, but here is where I put my light switches on my B3200....maybe this might give you an idea for your BX:
   / Bx24 aux lighting switches #5
I put my light switch on the FEL control plastic cover . To me, its the easiest way to put back to oem cheaply by buying a replacement plastic cover. However I am not convinced if I like it there.
   / Bx24 aux lighting switches #6
This is the only pic I have of my switches. If you blow it up, the switches (1 for two front facing trapazoids and 1 switch for a rear facing flood) are mounted below and to the left of the steering wheel - basically just under the existing light switches.
   / Bx24 aux lighting switches #7
On the fender worked well for me. Push forward for front aux lights and backward for front and rear aux lights.
   / Bx24 aux lighting switches #8
Your prob not looking for a rear switch but I add a small switch behind the seat one the left side it is easy and not in the way
   / Bx24 aux lighting switches #9
These are fantastic aftermarket switches. Been buying these for my Polaris Ranger.
OTRATTW
Deere 333G (A50120)
Deere 333G (A50120)
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
43016 (A51691)
43016 (A51691)
New Holland B95 Backhoe (A50490)
New Holland B95...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
