BX24 50hr Service
   / BX24 50hr Service #11
The fuel filters are supposed to be changed at 50 hours as well.
Not according to the Kubota WSM. They do say check them every 50 hours but the first scheduled change is at 500 hours.
Of course it doesn't hurt to change them but at Kubota's price I'll wait until I see contamination, but probably not 500 hours, maybe 200 or so:)
As for removing the cowling, you have to take off the bumper..they apparently have a gorilla on the assembly line installing that bumper, I had to use an impact wrench to bust loose those socket head screws holding it on, thought I was gonna break my 10mm allen socket. I could not bust em loose leaning on a 1/2" drive ratchet, and I weigh 250 lbs!
   / BX24 50hr Service #12
Yeah, I had the exact same issue!!! MY biggest gripe is the allen wrench though. I rather use the impact wrench to remove the grill so I installed the bolts in backwards so the nuts is facing front instead of behind. I really believe they should have done it this way or get specailized bolts so either allen wrench or 6 point socket can be used in the front.
   / BX24 50hr Service #13
Actually according to my copy of the WSM it states to check the fuel filter element every 100 hrs starting at 100hr service.
The section on checking the fuel lines and the fuel filter element reads like this:
The fuel line connections should be checked annually or every 100 service hours, whichever occurs first.
1. The fuel line is made of rubber and ages regardless of service period.
2. After inspection, if the fuel line and clamps are found damaged or deteriorated, replace them.
3. Check fuel filter. If it is clogged by debris or contaminated by water replace it.
There are some cautions and notes I left out for clarity.
So this begs the question if you are going to disconnect the filter from the fuel line to check it for debris or water, then I would just replace it. So that means to me, do an external check of the fuel lines and fuel filter and if the tractor is running fine then change the fuel filter every 500hrs.
About the 50hr service, the only things marked for service are the following:
Engine oil : Change
Engine oil Filter : Replace
Transmission oil Filter : Replace
Transmission fluid : Change
Engine Start System : Check
Greasing : -
Wheel bolt torque: Check (front wheels - 110-132 ft-lbs, back wheels - 80-96 ft-lbs)
That's it.
   / BX24 50hr Service #14
Besides the oils and filters changes when drained I would pull the tran screen and clean. At my 50 service there was a fair jag of metal in it on my bx23. I didn't mess with the 2 fuel filters and mine runs fine in 3.5 years. And I used one of those flute oil cap wrenches to take off Harbor freight also makes a oil filter plier that is about 1/4" thick at jaws if filter is round that would work so you didn't have to take anything (sheetmetal) off.
   / BX24 50hr Service #15
I just did both the fuel filters at the 200 hour mark on the advice of my dealer. It was a pain, particularly because I am 41 and in denial that I am losing my near vision. Lying on my back under the tractor to work with the filter under the tractor and keeping it in focus was not easy :D
If you are going to do the fuel filters, make sure you get some extra hose clamps when you get the filters. I broke one and used a zip tie as a substitute. I have the rear Bro-Tek skid plate and the left me with very little room to clamp the fuel line under the tractor.
In any case, you don't have to remove the grill guard to get the cowling off, but it does make it easier. The exhaust pipe has a small extender on it with a 45 degree bend. That extender comes off with a phillips screwdriver via a hose clamp. Once that is removed, the cowl will come off. You still have to remove the hinge bracket for the hood of course, but you don't have to remove the grill guard. I just unplugged the head lights, removed the hood, then removed the exhaust pipe extender and the cowl came off fairly easily.
   / BX24 50hr Service #16
Besides the oils and filters changes when drained I would pull the tran screen and clean. At my 50 service there was a fair jag of metal in it on my bx23. *I didn't mess with the 2 fuel filters and mine runs fine in 3.5 years. And I used one of those flute oil cap wrenches to take off Harbor freight also makes a oil filter plier that is about 1/4" thick at jaws if filter is round that would work so you didn't have to take anything (sheetmetal) off.
You R almost as bad as me.
I haven't changed the fuel filters since I got my bx23 over 50 months ago.
   / BX24 50hr Service #17
You are right, I misread the columns:cool:
   / BX24 50hr Service #18
My exhaust clamp on the elbow had no phillips drive in it, it was an 8mm hex head and was a little hard to get to. Next time I fool with it I am going to replace it with a phillips head/8mm clamp.
Well durn if you gotta take the hood and headlights off to get the cowling off vs the bumper/grill guard, I don't know which is worse. Now that I got those bolts loose and put back on with normal hand tight torque it will be a breeze next time;)
   / BX24 50hr Service #19
Now I don't feel too bad that I could not remove the bumper guard. My exhaust extender also would not budge but I removed the oil filter pretty easily from below.
   / BX24 50hr Service #20
No there are 2 filters .I found a second one while inspecting the under carriage along with 4 nuts that had backed off I think .But to the other filter its there ask the dealer for the second filter. Its up under about where the back of mmm.The mmm should be off.
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
2008 Ford F-250 XL (A50323)
2008 Ford F-250 XL...
Skid steer auger plate (A50322)
Skid steer auger...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
