BX24 12volt DC outlet power 2 55 watt lights?
   / BX24 12volt DC outlet power 2 55 watt lights? #1
NoviceguyInCT
CT, Litchfield County
BX24 TLB & old JD 400, JD H140
Anyone know whether the DC outlet on the new BX24 will power two 55 watt lights I plan to put on the ROPS to light up in front of the FL? Can the outlet handle these two simple lights?
Thanks for your comments and suggestions !
Jim
   / BX24 12volt DC outlet power 2 55 watt lights? #2
What is the current fuse capacity for this circuit?
Knowing the fused amperage capacity of the outlet will help with wattage limits.
   / BX24 12volt DC outlet power 2 55 watt lights? #3
I believe that it is protected by a 10 amp fuse, so it should handle 2 lights for the rops. However, there are leads in the back of the tractor for work lights that are protected by a 20amp fuse and this is what I used to plumb in 4 worklights, 2 pointed forward on the rops, two fogs for the rear. I have a switchbox mounted on the rops so I can choose the lighting I need. I have some pics at home and am happy to post them if you want them.
The wires you are looking for are centered right above the 3pt, taped up to a corrugated wire mold...you can't see them unless you look for them, they have bullet connectors for you to use. If you have any questions, let me know..happy to help.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
