BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #1
jcg42
Kubota
Very aggressive wasps made a nest overnight in the rollover bar, entering through the small holes for accessory mounts. I sprayed the hole from a distance and they've moved on or otherwise are no longer a problem. However, I am unsure how to clean out the residue which seems to be petroleum-based and has warnings about paint damage. I've rinsed out what I can with soap and water. There seems to be no way to get a brush or wire down in the hole to remove the nest. Any suggestions?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #2
pressure washer?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #3
Air hose nozzle pressed directly into the hole may dislodge some of it. Probably never be able to get rid of all of it.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #4
Spray some wd40 or CorrosionX in there. Wasps don’t like oily surfaces and help prevent rust.
  • Good Post
Reactions: JJT
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #5
I had a nest in my roll around cherry picker (engine crane). Found out at the worst time. 🤬 After spraying through the ends and all the holes, they were no more. After the nest dries out, they are easier to knock out. After a couple of whacks with a rubber mallet, it fell out of the end.
I keep tape over the ends and holes now. ;)
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #6
Spray some carb cleaner or brake cleaner in there and don't worry about it.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #7
I vote for a flamethrower.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #8
that will take care of the paint damage as well
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #10
Spray soapy water,. Spray rinse water.
2022 Club Car...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
2014 New Holland C238 Tracked Skid Steer (A50860)
2014 New Holland...
