BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #1
jcg42
Kubota
Very aggressive wasps made a nest overnight in the rollover bar, entering through the small holes for accessory mounts. I sprayed the hole from a distance and they've moved on or otherwise are no longer a problem. However, I am unsure how to clean out the residue which seems to be petroleum-based and has warnings about paint damage. I've rinsed out what I can with soap and water. There seems to be no way to get a brush or wire down in the hole to remove the nest. Any suggestions?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #2
pressure washer?
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #3
Air hose nozzle pressed directly into the hole may dislodge some of it. Probably never be able to get rid of all of it.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #4
Spray some wd40 or CorrosionX in there. Wasps don’t like oily surfaces and help prevent rust.
  • Good Post
Reactions: JJT
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #5
I had a nest in my roll around cherry picker (engine crane). Found out at the worst time. 🤬 After spraying through the ends and all the holes, they were no more. After the nest dries out, they are easier to knock out. After a couple of whacks with a rubber mallet, it fell out of the end.
I keep tape over the ends and holes now. ;)
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #6
Spray some carb cleaner or brake cleaner in there and don't worry about it.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #7
I vote for a flamethrower.
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #8
that will take care of the paint damage as well
   / BX23S wasp nest in roll bar / sprayed wasp killer / how to clean out? #10
Spray soapy water,. Spray rinse water.
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2005 Cadillac STS Sedan (A48082)
2005 Cadillac STS...
2003 Volvo S60 Sedan (A50860)
2003 Volvo S60...
197390 (A50459)
197390 (A50459)
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
