Tires BX23S backhoe and 3pt hitch?
   / BX23S backhoe and 3pt hitch? #1
trueg50
Central VT
Kubota B2601
I recently purchased a house on 60 acres with ~5 acres semi-open and the rest wooded with lots of logging trails. I have a bit of some landscaping projects around the house the missus is requesting so a backhoe is a must have. Looking at a BX 23S I see that it doesn't come with the 3pt hitch system arms since folks might never use them. What I haven't heard is, if I go ahead and put in the 3 pt hitch setup, can I still easily pop on/off the backhoe? Or do I need to reassemble the 3 pt hitch every time I go from backhoe to rear implement?
   / BX23S backhoe and 3pt hitch? #3
I have the previous version TLB BX25D. It is a pita to handle the 3ph off and on but having the subframe makes for a real solid hoe tractor combination. I’ve just added fast hitch ends to the lower lift arms which will make the transition more awkward but with a little planning swapping back and forth can be minimized. The BX23S has some nice new features mine doesn’t have. Good luck!
   / BX23S backhoe and 3pt hitch? #4
I recently purchased a house on 60 acres with ~5 acres semi-open~ 55 acres wooded with lots of logging trails.
How much tractor experience have you had?
A BX tractor will be fine for landscaping five acres. Slow, but fine.
Due to BX 9" ground clearance and teensy front wheels every >6" fallen branch, every burrow, every hole will impede BX access to your 55 wooded acres.
Neophyte tractor operators are often intimidated by instability of compact tractors with small front wheels and large rear wheels, therefore frequently purchase tractors too light, too small for long term satisfaction. ((Tractors seem to shrink after about twenty hours of operating experience.))
Several reasons owner/operators trade up from Subcompact Tractors:
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
More tractor weight.
More FEL lift capacity.
Larger wheels and tires have a larger tire/tread "patch" in contact with the soil. Larger wheels and tires bridge small holes, ruts and tree debris maintaining traction, which stall subcompact tractors. As a result, larger wheels/tires yield more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires decrease operator perturbation operating over rough ground.
Subcompact and compact tractors under 3,000 pounds bare weight operate in landscape, kitchen/commercial garden or hobby farm applications on one to ten flat acres.
   / BX23S backhoe and 3pt hitch? #5
In all deference to Jeff, I happen to like the BX for the woods over larger tractors. For me the BX is more maneuverable on trails.
Our camp has four owners. When we were tractor shopping, I wanted an L. I was over ruled. Ended up with a BX and it has done well on our 127 acres. Glad I was over ruled on the L. The BX will not set any speed records, but for box blading, pushing fallen trees off the trails and bush hogging, it is all the tractor we need.
Will not suit everyone, but I would not discount the BX just because of its' size.
One of the neighbors got an L39 series with a back hoe for his mountain ground. He needed that big of a machine because of the slopes, but that thing is big for the woods.
Happy shopping
   / BX23S backhoe and 3pt hitch? #6
Wife is mowing the yard and lower orchard now with the B26. More acreage, woods, grapple? I would get a little bigger tractor. Fun size and lots safer on the slopes. It replaced a B20 after 23 years. She’s happy, I’m happy. Best return on my investment.
Thanks for the info and advice folks!
I'm definitely on the fence about the BX. At the price point I can get the tractor, backhoe, and snowblower (maybe another implement) to meet the basic needs and let me haul wood (in a carryall/bucket). I'd much rather be in a b-series machine but the costs certainly are a bit more. The property has good roads, but to get to a few areas with nice trees would take a little work to improve the trails.
Oh well, back to Craigslist and the kubota tractor building tool :)
   / BX23S backhoe and 3pt hitch? #9
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
