BX2380 12v accessory outlet question
   / BX2380 12v accessory outlet question #1
ericbx1500
Michigan
BX2380, scotts 48
Just picked up a BX2380 and noticed that my 12v accessory outlet polarity is backwards. Positive is on the side terminal and negative is the center one. Is this normal for this plug? Has anyone else checked theirs?
It ended up being wired wrong at outlet.
   / BX2380 12v accessory outlet question #3
I wonder if the outlet was installed by the dealer? Congrats on catching the issue before you burned something up.
Installed at factory. I don't think I would have burned anything up since it was still fused but my LED light would not work the way it was wired since LED's are polarity sensitive.
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
UNUSED INDUSTRIAS AMERICA HI-900 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
