BX2370 loader -vs- something larger
/ BX2370 loader -vs- something larger #21
You've kinda got me thinking about the L's again.
Coming up on 50hrs. Planning to have the tires filled and add wheel weights. Box blade (or maybe that Ratchet Rake instead).
We've been talking about a rototiller, but not quite sure it's worth buying -vs- renting.
Your a very indecisive person lol
Cough* M7 Cough*
/ BX2370 loader -vs- something larger #24
I googled kubota's biggest tractor and it showed 130hp, later I found the 168hp M7, I didn't feel like correcting myself but I see you did lol.
Probably was accurate at the time, but things change. :thumbsup:
/ BX2370 loader -vs- something larger #25
BX2370B2320BX2680B2601B2650
LoaderLA243ALA304LA344LA434LA534A
500mm max height518545659827
pivot pin, max height7457729481146
I bought the BX2370 predominantly to build / rebuild a bunch of privacy fence. Thinking post-hole digger and a powered wheelbarrow. Also wanted to address several landscaping / deferred maintenance issues.
It's been great in that regard. Discovered a bunch of uses for it that I'd hadn't anticipated. Also realized some things are a lot heavier than I would have guessed. Weight matters.
Wishing it could lift more, I'd been glancing at specs and comparing the 518lb (500mm, max height) on the BX2370 -vs- 948lb (pivot pin, max height) on the B2601.
Got me thinking I could get nearly twice the lifting ability for not a lot more money. I finally wrote some numbers down so I could see things side-by-side.
Not as much difference as I thought.
I think it's a mistake to compare these tractors at max height, since they have different sizes and FELs. The 2650 max height is probably quite a bit higher than the BX, right? A fair comparison would be to consider them all at the same height, in which case the 2650 will look even better. This matters because the lift capacity is weakest at max height and increases as the loader goes down. The 2650 capacity will be higher at an equivalent height to the BX's max.
You really need to consult the lift curve in the owners manual for the FEL to get a feel for this. And realize that most of us use the loaders to lift stuff down low, where the lift capacity is much much greater. If I remember right, the capacity on my L3200 near ground height is more than double the capacity at full height.
/ BX2370 loader -vs- something larger #26
There's a reason they lowered the pressure, the little Kubota's got a bad name for blowing hydraulic hoses.
Something to do carefully
Have never heard that. Anyway, even if it were true, it's a heck of a lot cheaper and easier to replace hydraulic hoses than all those cracked JD PTO housings... :thumbsup:
wrooster
/ BX2370 loader -vs- something larger #27
I have a BX and my neighbor has a B, and they both have their strengths.
The B has 4" more ground clearance at the axles, which in some cases will make it more suitable for use in the field (e.g. tilling) or in the woods (e.g. dragging timber).
The BX weighs approximately 300lbs less, and has a lower center of gravity, which in some cases will make it more suitable for estate mowing due to less ground compaction and additional stability on hills.
After 6 (7?) years of BX ownership, i want for only two things:
1) A bigger bucket. More often than not I am moving loose material (e.g. topsoil or mulch) and the weight is well within the loader capacity; what I really need is a bucket that is 1.5 or more times the volume, which would reduce the number of trips between the pile and the destination. In the wheeled-loader world, these upsized buckets are called "loose material" buckets. It is the case that if you fill such a bucket with (example) stone aggregate, the loader may not be able pick it up; but that is not the purpose.
2) Better lighting fore and aft.
wrooster
Very good point. Thank you.
What is the term for lift capacity at "ground level" or something like that?
/ BX2370 loader -vs- something larger #30
My 1,200lbs rated loader on my L3200 would get "1,200lbs" big square bales to 4-5'. Add in the 200+ lbs for the forks & the bales sticking 4' out and it was dealing with 20-30% more than rated capacity. More down low, yes, but not near double.
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
1979 HEIL TRANSPORT TRAILER (A60736)
1979 HEIL...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
