BX2370 bubbles in HST
   / BX2370 bubbles in HST #1
chucky79
Ashland, KY
Kubota BX2370-1, Cub Cadet 1812, Cub Cadet 1810, Cub Cadet 1650
I have a new bx2370 with 23hrs on it and noticed i have bubbles visible in my HST fluid when i pull the dipstick after working with the tractor. They pop/dissipate or whatever you wanna call it after a short time and the fluid looks clear and normal color. Fluid level checks out good since getting it and hasn't dropped or leaked anywhere that ive noticed. Does this sound normal to you all?
   / BX2370 bubbles in HST #2
Does it run and pull ok? If so, don't worry about it. If the level is ok I'd say your good. The only thing that would cause bubbles would be an air leak.
I used the bx today to mow and haul for about 2 hours and everything seemed ok. I tried to get a pic of the bubbles but the light and angle was to difficult. I did get right off and pull the dipstick to check the bubbles and watched them disipate. took about 15 seconds and they all popped and the fluid was clean and clear again. I called my dealer and he said not to worry but he would check for air leaks at my service. I read online about foam and water in fluid but doesnt look like that. I think its almost like carbination on the top of a glass of soda. Small bubbles that clear out quickly if that make sence... Someone else pointed out there are gears in there moving and causing a disturbance in the fluid so these bubbles are to be expected. the fact that they clear out so quickly shouldnt be any concern and sounds normal. yall agree?
   / BX2370 bubbles in HST #4
I was having some steering issues with a Kubota F3080 which just recently got resolved but prior to resolving what was causing the issue Steve Barlow told me to check and see if there were bubbles on the dipstick when the intermittent problem happened on mine. Never any bubbles and have never seen any bubbles on other Kubotas and I've had a few.
First off I wouldn't worry about it, I'd just use the machine like it is perfect. If the bubbles are a real problem then you'll start having issues which will be covered under warranty. It seems possible that air has gotten into the system which could have happened during the original filling and they may work themselves out of the system. If they continue then inform the dealer when you take it in for first service, which I would only do if there are warranty issues or other needs for service or if first service is free.
First 50 hour service is really easy to do and good for owner to do to get better aquainted with your machine.
In my opinion, no, it's not normal to have visible bubbles on the dipstick but it's not something I'd worry about unless it continues after the first 30 to 40 hours. If so, then there is an air leak or open valve letting air into the system. There is an air relief valve which can be heard fairly well when one steers/turn steering wheel which is more noticeable on some Kubotas models more than others.
Mine are the original factory filters. Just got BX in May and has 27 hours on it as of today. Need anymore info?
   / BX2370 bubbles in HST #7
I'm no expert in hydraulics but if the level hasn't went down and there are no leak's,
I would think it's just working the air out of the system, being that new.
If thats the case, they should go away in time.
If the filters are not allowing full flow bubbles may form. ? ?
i assume they are being that they are OEM, New, and only have 27 hours. How could a guy test this?
   / BX2370 bubbles in HST #10
Only way is to look at the filters but that means draining all the oil. Too much work for just a guess and seeing all is working fine.
378576 (A51573)
378576 (A51573)
90018 (A48082)
90018 (A48082)
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2019 JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
2019 JOHN DEERE...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
