BX2360 Upgrades
/ BX2360 Upgrades #21
Are you talking about something like this?
StabilWorks
Triple, the way I read the question, it is in reference to the telescoping end links- they extend out to hook up to the pins easier, and then ratchet back in when you back up.
/ BX2360 Upgrades #22
OK, thanks, I didn't know that feature was available on the B Series.
/ BX2360 Upgrades #23
Nice idea for the tie downs Roger.
I'm still hunting for a trailer.
I have some nice heavy tie down straps similar to yours already.
I've been wondering how i will hook them up.
I may have to copy a similsr style.
Looks great.
Tom
/ BX2360 Upgrades
Looks great.
Tom
Thanks, but it was not my idea. There is a company that makes them. I have not used them yet.
I am now working in a set of work lights.
/ BX2360 Upgrades #25
I have set of telescopic lower links that I used on my little Yanmar. The extra length allowed the arms to go lower and higher. However pushing the weight back that far blew out the o-ring in the 3 point lift cylinder. So if you were to try this be cautious on how much weight you are lifting.
Here is my thread on the repair: http://www.tractorbynet.com/forums/yanmar/202252-169d-3-point-hitch-weak-8.html
/ BX2360 Upgrades #26
94Bullitt, very nice work on your BX! Everything looks very professionally done, I really like the Kmatch. :thumbsup:
/ BX2360 Upgrades #28
One thing I always did not like about the bx was the hood rattled when you start or shut the tractor off. It was annoying and embarrassing. I got a set of furniture bumpers at Lowes. Here are some pictures of where I put them. The hood does not rattle anymore.
Thank you, thank you, 94Bullitt. That was simply the cheapest, quickest, easiest, and one of the most satisfying modifications I've made to my BX25. I had a couple of rubber feet left over from an electronics project that were .25" thick x.75"x.75". I put them where you did and the hood rattle is GONE!
/ BX2360 Upgrades
No problem, I am glad you liked it.
/ BX2360 Upgrades
I have been working on some lighting upgrades. I made 2 brackets for work lights. I had 2 lights laying around from the Bobcat that I used. I put a switch in the light itself. Here is the link to thread were I did that. I wired the lights up so that they can only be turned on with the headlights. I took the factory connector a part for the tail light and added the wires for the worklights. I ordered a 3rd light from Northern Tool but it had 3 LEDs out so I sent it back and I am still waiting for them to send me a replacement. Once I get it I will get some better pictures and a night time shot. I welded the bolts to the clamp for a clean install and I used some sticky foam to insulate it so it won't scratch the ROPS.
/ BX2360 Upgrades
Well I got the 3rd light from Northern Tool today and it worked!
On the left side bracket I added a 12v power port because I use a strobe light when I mow along the road. The power power under the seat does not work that well to run the wire to the top of the ROPS.
I also added a LED strip light to the top of the ROPS. When you have the QH and a implement on you can't see the tail lights that well.
Here is a picture from the back with the 2 foward facing lights on. I need to play around with the adjustment. It was too cold to night to mess with it much. Once I get them adjusted I will take some more pictures with a actual camera not my tablet. The lights are flood lights they throw a really wide beam.
/ BX2360 Upgrades #32
WOW! You certainly see *THAT* cyclops light! Excellent addition!
/ BX2360 Upgrades #34
What did you use for the strip light on the ROPS?
/ BX2360 Upgrades #40
Nice job Bullitt! now I'm gonna have to find a way to sneak some LED lighting in the buggy next time I'm shopping with the wife! LOL:smurf:
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2011 JACK COUNTY 130 BBL VACUUM TRAILER (A63569)
2011 JACK COUNTY...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
EZ Trail 3400 (A63118)
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
