BX2360: Two Service Questions
   / BX2360: Two Service Questions #1
sw18x
Looking
1.) How often do you guys change the oil after the initial 50 hr. service?
2.) I just changed both fuel filters at 102 hours. I noticed what appears to be another fuel filter plumbed into the fuel line just forward of the fuel filter underneath the tractor, except it's metal instead of plastic. Why doesn't the manual mention this filter? Should it be changed?
   / BX2360: Two Service Questions #2
I would have to check my manual to be sure. Someone on here fixed up an Exel Service guide for the BX2360, but it's on a different computer, 150 hours sounds familiar.
Have you seen this?
Kubota BX Service
   / BX2360: Two Service Questions #3
That's the fuel pump.
Thanks. Fuel pump...duh. Got it.
   / BX2360: Two Service Questions #5
Some just follow the manual's schedule, roughly, while others put enough time on their machine (60-80 hours) to just change it annually, paying little attention to the actual hour meter. Some are spring changers, while others are fall changers.
I'm one of the latter.
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
