BX2360 maxed out with 11" of snow in Central Virginia
   / BX2360 maxed out with 11" of snow in Central Virginia #31
Yesterday was a blower-plow-blower day. Use the blower to remove most of the snow from our gravel/rock/sand drive. Follow that up with plowing the inch or so left on the ice to one side of the drive. Reinstall the blower and get rid of the plowed up piles. Kubota has a slick system for making changing front implements easy. If needed I can always use the FEL to knock down the piles by the end of the drive.....Lots of tractor time is fun but I really want Spring to get here soon!!!!!!!
I ended up using the FEL and my Box Blade for more weight on the rear of the tractor. It'll probably be awhile before I get to play in that much snow again.
   / BX2360 maxed out with 11" of snow in Central Virginia #33
I cleared snow last May 2nd, 14" of stuff so heavy it turned blue as you pushed it up. I used my bucket the entire time. The blade was almost useless in stuff that deep/heavy. I had my bucket in float, pushed it so hard my front wheels lifted and then my rear tires chirped when I spun out. It's a little late now, but if you don't have your tires loaded, that makes a huge difference. The box blade should have made a world of difference, too.
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
John Deere 1790 Planter (A50514)
John Deere 1790...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
Wolverine Quick Attach Skid Steer Rock Rake (A50514)
Wolverine Quick...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
