3-Point Hitch BX2360 2011
   / BX2360 2011 #1
Rfisher7381
South West Michigan
Kubota BX2360
Is there a way to set PTO height? I am using a rotary cutter 4 ft, and would like to reproducibly have the PTO return to the same height. Really just a PTO stop. I have the mmm PTO set to top. Thanks
   / BX2360 2011 #2
Your question is confusing. The TOP setting on the MMM is for the height of the deck itself. The driveshaft has a universal joint on each end and slides to lengthen or shorten as you raise and lower the mower. The PTO doesn't move.
Same on the rear end. The PTO doesn't move, the 3pt arms are free to travel full distance up and down. There is no where to make the 3pt stop at a set height. What you can do though is add some chains off the 2 dog-ear loops just inside the tail lights down to the 3pt arms. This will give you a bottom limit for your hog.
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2013 DRAGON  130BBL VACUUM TRAILER (A50854)
2013 DRAGON...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
