Snow BX2350 with FEL mounted SNOW PLOW.. Just and Idea?
   / BX2350 with FEL mounted SNOW PLOW.. Just and Idea? #11
</font><font color="blue" class="small">( Step n tow receiver hitch mounted upside down in the bucket with extra steel reinforcement underneath. )</font>
Have you plowed snow with this setup? How does it work?
Have you plowed anything but snow? Dirt? Gravel?
Bob
   / BX2350 with FEL mounted SNOW PLOW.. Just and Idea? #12
My bucket attaches with 4 - 1" pins. At first I attached a 7 1/2' old truck plow blade to my bucket with turnbuckles and straight bladed the driveway. The problem with that was deep snow would go over the top of the blade and fill the bucket. Shortly after I welded on pieces of c-channel to the back of the plow blade with 1" holes in the right areas. Now when I need to plow snow I just pull 4 pins, remove the bucket and attach the 7 1/2' blade with the same 4 pins. It's not an angling blade but with some ingenuity I'm sure I could make it one if I wanted to.
   / BX2350 with FEL mounted SNOW PLOW.. Just and Idea? #13
Have two winters of snow plowing under my belt with this setup. It works great. Best part is being able to pull a pin and use the bucket.
Only for snow, though. The blade isn't made for gravel, etc. and have never used it that way. I have plenty of back blades and box blade for that type of work.
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2012 RAM 5500 (A52472)
2011 Hyundai Sonata (A50324)
2011 Hyundai...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2024 Spartan KGZ-XD Zero Turn Mower (A50514)
2024 Spartan...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
