BX2350 Warranty issues - Seat / Fender fix
   / BX2350 Warranty issues - Seat / Fender fix #1
Musclford
Central, IL - USA
BX2350
Ok,
I bought my tractor while in AR/MO.. now am in IL, so my original dealer is too far away to maintain my tractor..
Reluctantly, I called the local dealer, asked for service and explained my situation with him citing all the part numbers for the upgraded items including the PIB for the new seat.
Seats are on order and should arrive in SEPT. and will cost me $25.00. Fine with me.
Asked about the fender issues and mine aren't broken yet but I want the upgrade... He said yep we know all about it but they can't just replace them, they have to wait till the customer requests it.. He said it was kinda wierd, but nonetheless he would order all the parts and call me when they arrive so I can get them installed.
Then, I ask about the guage/tach, knobs and other items that were mentioned on here and he said they would take care of everything when I bring it in for the fenders....Including the low oil level in the frt axle that I never filled up..
He also knew about the abrupt stop, but says Kubota designed it that way, no fixey... So providing they follow through with everthing he said, I'll be one big happy camper when we are done...
I asked if the fenders have to be cracked to repair and he said NO, if so, we'll crack them and he understood why I would want the upgrade done regardless if they are cracked or not....
Call your dealer and try the same thing... Looks like it's working for my non-original dealer....
Phil
   / BX2350 Warranty issues - Seat / Fender fix #2
Replacing the fender is kind of a pain if you are doing it yourself. Personally, as long as the step kit is installed it doesn't seem possible to break the fender whether old or new. You definitely don't want the new fender without also adding the step kit. The step kit transfers the load from the fender to the tractor frame. You can jump up and down on the floor without worry after the step kit is installed. If you can get the new fender installed for free, great. If not, make sure you get the kit installed and then don't worry about it.
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
