BX2350 vs. BX2360
   / BX2350 vs. BX2360 #1
wvhillbillyjlm
Can someone tell me the differences between these two tractors, if any?
Thanks
   / BX2350 vs. BX2360 #2
When Kubota updated to the 60 series, they re-adjusted the hydro trans to be less jerky. Small touches here and there in improvements, but most obvious was the return to metal rear fenders.
The differences are not huge, the jerky HST versus the "roll a bit" HST was big!
   / BX2350 vs. BX2360 #3
I had a BX2350 and several other models of B's and BX's for reference. I traded the BX2350 very soon after buying it for the BX2660 because of the jerky transmission in reverse on the BX2350. Also the seat safety cutoff switch on the BX2350 was so bad it would constantly cut off when my wife drove it and for me when going down hill on a hill side property. Seat cut off issue did have an easy fix. The hood didn't fit close on the BX2350 but that wasn't an issue for me, didn't care metal vs plastic.
Unless a big discount I'd never buy a BX2350 unless the property was flat and needed to rarely use reverse. Straight ahead mowing on flat land the BX2350 is fine.
   / BX2350 vs. BX2360 #4
You hear it all the time, but do a search on this forum. loads of information and debate on this exact subject. But for a quick summary... Go with the BXxx60 series if at all possible and you will be the happiest
   / BX2350 vs. BX2360 #5
Major difference are (I had a BX1850 and now a BX1860):
  • - Smoother stopping coming out of reverse on 60 series.
  • - Metal hood and fenders on the 60 series. Plastic on the 50.
  • - Hydraulic pressure at idle (but very little) on 60 series. On the 50 series, you have to advance the throttle to gain pressure
  • - Seat switch moved to bottom of seat (60) from seat frame on the 50 series
  • - Can't think of anything else of note
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
