BX2350 PTO Select Lever Stuck
   / BX2350 PTO Select Lever Stuck #1
Ken_O
I Used the grass catcher to pick up leaves today and the shute clogged up several times. I wasn't shure the rear PTO was running so I shifted the PTO select lever to the Rear PTO position and then tried to shift it back to the Mid-Rear PTO position and it the PTO shift lever won't move now. It is stuck in the Rear position. Any ideas what is wrong, how to free it up. This is the first time I used the bagger this year and it worked OK for a few minutes and then I had this problem.
Thanks for your help,
Ken...
   / BX2350 PTO Select Lever Stuck #2
Try engaging the PTO for a sec, let it spin back down and try the lever again.
"bump" it. :)
   / BX2350 PTO Select Lever Stuck #3
Agree with rdsaustnx, may have to do it a couple of times.
Thanks for the suggestion, it worked. I just engaged the PTO for a moment and after a couple of times I was able to move the PTO Select Lever.
Thanks again,
Ken....
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 GIYI GY-PG72C...
Volvo Hydraulic Loader Bucket (A50322)
Volvo Hydraulic...
2014 John Deere 3033R (A50120)
2014 John Deere...
