Oil & Fuel BX2350 losing power
   / BX2350 losing power #12
Thinking like you would a car, the main pump is on the back drivers side of the engine. I've never heard of anybody messing with any kind of screen on a BX though, so I don't think there is one.
Well I finally found the problem that has been bothering me for the last year and after many fuel filter changes I discovered that there was an air bubble in the fuel line between the tank and the first fuel filter just above the differential which explains why the problem always got worse when the tractor had been running for awhile. The transmission would heat up the air bubble which would expand and cut off the fuel flow. I blew compressed air through the fuel line to blast out the bubble, problem solved.
Would kinda sorta been nice to figure this out BEFORE removing the deck, roll bar and fenders, but such is life Huh.
   / BX2350 losing power #14
Well that's the way things go when troubleshooting sometimes. Hats off to you for figuring it out in the end.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
UNUSED FUTURE 5T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 5T...
Rhino 484 (A50322)
Rhino 484 (A50322)
2012 Ford F-150 FX2 (A50323)
2012 Ford F-150...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
