bx2350 I.D this wire connector
   / bx2350 I.D this wire connector #1
gregz
Hoosier
BX 2350
Hi Can someone ID this wire connector, it pigtails out of the rear light loom. Appears the PO put a jumper wire in it ? What is it's purpose. Cheers
   / bx2350 I.D this wire connector #2
I suspect it's for a worklight should you choose to purchase one. It will have power only when the key is turned on.
   / bx2350 I.D this wire connector #3
That is not a connector with for a work light with two wires the same color and operating with a jumper.
It is going to be for some safety feature that has been bypassed.
Go through the attached recommended maintenance checks for engine starting and I think you will find what it is for if you leave the jumper out.
In view of its location near the right rear fender I suspect the pto
Dave M7040
  • forum BX2350.pdf
Safety switch, that makes sense. Probably from the seat as I can start with seat up or not sitting on it . PTO safety switch works .Thanks
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
19008 (A56859)
19008 (A56859)
Hustler super Z zero turn (A56857)
Hustler super Z...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
